Alert / Notification on Cannot create item: item with the same key .. already exists.
  • Tulkis
    • Feb 2019
    Hi all,
    We have some custom discovery rules in a template and sometimes the discover send a wrong value causing the "Cannot create item: item with the same key "xxxx" already exists."
    Is there any chance to set up an alert / notification, we could configure to check this?
    The discovered items are fed from an api and sometimes this api fails, it causes the items marked to delete and were not monitored anymore.
    Thanks in advance.
