From time to time on my zabbix server i receive the following error: "zabbix history syncer processes more than 75 busy". When this happens the server show all the host monitored by agent down, the interface its slow and eventually crash. Then i need to reboot the operating system to bring the server back online.
Zabbix ver.: 2.0.12
DB: mysql
OS: centos 6.5
Some printscreen and graphs for you to understand better the problem with my zabbix server:
https://drive.google.com/open?id=0B_NFTkthQa4xVGVqQUx1c2ExWnM&authuser=0
And of course zabbix_server.conf:
Zabbix ver.: 2.0.12
DB: mysql
OS: centos 6.5
# This is a configuration file for Zabbix Server process
# To get more information about Zabbix,
# visit http://www.zabbix.com
### Option: NodeID
# Unique NodeID in distributed setup.
# 0 - standalone server
# Mandatory: no
# Range: 0-999
# Default:
# NodeID=0
### Option: ListenPort
# Listen port for trapper.
# Mandatory: no
# Range: 1024-32767
# Default:
# ListenPort=10051
### Option: SourceIP
# Source IP address for outgoing connections.
# Mandatory: no
# Default:
# SourceIP=
### Option: LogFile
# Name of log file.
# If not set, syslog is used.
# Mandatory: no
# Default:
# LogFile=
LogFile=/var/log/zabbix/zabbix_server.log
### Option: LogFileSize
# Maximum size of log file in MB.
# 0 - disable automatic log rotation.
# Mandatory: no
# Range: 0-1024
# Default:
# LogFileSize=1
LogFileSize=0
### Option: DebugLevel
# Specifies debug level
# 0 - no debug
# 1 - critical information
# 2 - error information
# 3 - warnings
# 4 - for debugging (produces lots of information)
# Mandatory: no
# Range: 0-4
# Default:
# DebugLevel=3
### Option: PidFile
# Name of PID file.
# Mandatory: no
# Default:
# PidFile=/tmp/zabbix_server.pid
PidFile=/var/run/zabbix/zabbix_server.pid
### Option: DBHost
# Database host name.
# If set to localhost, socket is used for MySQL.
# If set to empty string, socket is used for PostgreSQL.
# Mandatory: no
# Default:
DBHost=localhost
### Option: DBName
# Database name.
# For SQLite3 path to database file must be provided. DBUser and DBPassword are ignored.
# Mandatory: yes
# Default:
# DBName=
DBName=zabbix
### Option: DBSchema
# Schema name. Used for IBM DB2.
# Mandatory: no
# Default:
# DBSchema=
### Option: DBUser
# Database user. Ignored for SQLite.
# Mandatory: no
# Default:
# DBUser=
DBUser=zabbix
### Option: DBPassword
# Database password. Ignored for SQLite.
# Comment this line if no password is used.
# Mandatory: no
# Default:
DBPassword=zabbix
### Option: DBSocket
# Path to MySQL socket.
# Mandatory: no
# Default:
# DBSocket=/tmp/mysql.sock
DBSocket=/var/lib/mysql/mysql.sock
### Option: DBPort
# Database port when not using local socket. Ignored for SQLite.
# Mandatory: no
# Range: 1024-65535
# Default (for MySQL):
# DBPort=3306
############ ADVANCED PARAMETERS ################
### Option: StartPollers
# Number of pre-forked instances of pollers.
# Mandatory: no
# Range: 0-1000
# Default:
StartPollers=50
### Option: StartIPMIPollers
# Number of pre-forked instances of IPMI pollers.
# Mandatory: no
# Range: 0-1000
# Default:
# StartIPMIPollers=0
### Option: StartPollersUnreachable
# Number of pre-forked instances of pollers for unreachable hosts (including IPMI).
# Mandatory: no
# Range: 0-1000
# Default:
StartPollersUnreachable=25
### Option: StartTrappers
# Number of pre-forked instances of trappers.
# Trappers accept incoming connections from Zabbix sender, active agents, active proxies and child nodes.
# At least one trapper process must be running to display server availability in the frontend.
# Mandatory: no
# Range: 0-1000
# Default:
# StartTrappers=5
### Option: StartPingers
# Number of pre-forked instances of ICMP pingers.
# Mandatory: no
# Range: 0-1000
# Default:
StartPingers=10
### Option: StartDiscoverers
# Number of pre-forked instances of discoverers.
# Mandatory: no
# Range: 0-250
# Default:
# StartDiscoverers=1
### Option: StartHTTPPollers
# Number of pre-forked instances of HTTP pollers.
# Mandatory: no
# Range: 0-1000
# Default:
# StartHTTPPollers=1
### Option: JavaGateway
# IP address (or hostname) of Zabbix Java gateway.
# Only required if Java pollers are started.
# Mandatory: no
# Default:
# JavaGateway=
### Option: JavaGatewayPort
# Port that Zabbix Java gateway listens on.
# Mandatory: no
# Range: 1024-32767
# Default:
# JavaGatewayPort=10052
### Option: StartJavaPollers
# Number of pre-forked instances of Java pollers.
# Mandatory: no
# Range: 0-1000
# Default:
# StartJavaPollers=0
### Option: SNMPTrapperFile
# Temporary file used for passing data from SNMP trap daemon to the server.
# Must be the same as in zabbix_trap_receiver.pl or SNMPTT configuration file.
# Mandatory: no
# Default:
# SNMPTrapperFile=/tmp/zabbix_traps.tmp
SNMPTrapperFile=/var/log/snmptt/snmptt.log
### Option: StartSNMPTrapper
# If 1, SNMP trapper process is started.
# Mandatory: no
# Range: 0-1
# Default:
# StartSNMPTrapper=0
### Option: ListenIP
# List of comma delimited IP addresses that the trapper should listen on.
# Trapper will listen on all network interfaces if this parameter is missing.
# Mandatory: no
# Default:
# ListenIP=0.0.0.0
# ListenIP=127.0.0.1
### Option: HousekeepingFrequency
# How often Zabbix will perform housekeeping procedure (in hours).
# Housekeeping is removing unnecessary information from history, alert, and alarms tables.
# Mandatory: no
# Range: 1-24
# Default:
# HousekeepingFrequency=1
### Option: MaxHousekeeperDelete
# The table "housekeeper" contains "tasks" for housekeeping procedure in the format:
# [housekeeperid], [tablename], [field], [value].
# No more than 'MaxHousekeeperDelete' rows (corresponding to [tablename], [field], [value])
# will be deleted per one task in one housekeeping cycle.
# SQLite3 does not use this parameter, deletes all corresponding rows without a limit.
# If set to 0 then no limit is used at all. In this case you must know what you are doing!
# Mandatory: no
# Range: 0-1000000
# Default:
# MaxHousekeeperDelete=500
### Option: DisableHousekeeping
# If set to 1, disables housekeeping.
# Mandatory: no
# Range: 0-1
# Default:
# DisableHousekeeping=0
### Option: SenderFrequency
# How often Zabbix will try to send unsent alerts (in seconds).
# Mandatory: no
# Range: 5-3600
# Default:
# SenderFrequency=30
### Option: CacheSize
# Size of configuration cache, in bytes.
# Shared memory size for storing host, item and trigger data.
# Mandatory: no
# Range: 128K-2G
# Default:
CacheSize=12M
### Option: CacheUpdateFrequency
# How often Zabbix will perform update of configuration cache, in seconds.
# Mandatory: no
# Range: 1-3600
# Default:
# CacheUpdateFrequency=60
### Option: StartDBSyncers
# Number of pre-forked instances of DB Syncers
# Mandatory: no
# Range: 1-100
# Default:
# StartDBSyncers=4
### Option: HistoryCacheSize
# Size of history cache, in bytes.
# Shared memory size for storing history data.
# Mandatory: no
# Range: 128K-2G
# Default:
# HistoryCacheSize=8M
### Option: TrendCacheSize
# Size of trend cache, in bytes.
# Shared memory size for storing trends data.
# Mandatory: no
# Range: 128K-2G
# Default:
# TrendCacheSize=4M
### Option: HistoryTextCacheSize
# Size of text history cache, in bytes.
# Shared memory size for storing character, text or log history data.
# Mandatory: no
# Range: 128K-2G
# Default:
# HistoryTextCacheSize=16M
### Option: NodeNoEvents
# If set to '1' local events won't be sent to master node.
# This won't impact ability of this node to propagate events from its child nodes.
# Mandatory: no
# Range: 0-1
# Default:
# NodeNoEvents=0
### Option: NodeNoHistory
# If set to '1' local history won't be sent to master node.
# This won't impact ability of this node to propagate history from its child nodes.
# Mandatory: no
# Range: 0-1
# Default:
# NodeNoHistory=0
### Option: Timeout
# Specifies how long we wait for agent, SNMP device or external check (in seconds).
# Mandatory: no
# Range: 1-30
# Default:
# Timeout=3
### Option: TrapperTimeout
# Specifies how many seconds trapper may spend processing new data.
# Mandatory: no
# Range: 1-300
# Default:
# TrapperTimeout=300
### Option: UnreachablePeriod
# After how many seconds of unreachability treat a host as unavailable.
# Mandatory: no
# Range: 1-3600
# Default:
# UnreachablePeriod=45
### Option: UnavailableDelay
# How often host is checked for availability during the unavailability period, in seconds.
# Mandatory: no
# Range: 1-3600
# Default:
# UnavailableDelay=60
### Option: UnreachableDelay
# How often host is checked for availability during the unreachability period, in seconds.
# Mandatory: no
# Range: 1-3600
# Default:
# UnreachableDelay=15
### Option: AlertScriptsPath
# Full path to location of custom alert scripts.
# Default depends on compilation options.
# Mandatory: no
# Default:
# AlertScriptsPath=${datadir}/zabbix/alertscripts
AlertScriptsPath=/usr/lib/zabbix/alertscripts
### Option: ExternalScripts
# Full path to location of external scripts.
# Mandatory: no
# Default:
# ExternalScripts=${datadir}/zabbix/externalscripts
ExternalScripts=/usr/lib/zabbix/externalscripts
### Option: FpingLocation
# Location of fping.
# Make sure that fping binary has root ownership and SUID flag set.
# Mandatory: no
# Default:
# FpingLocation=/usr/sbin/fping
### Option: Fping6Location
# Location of fping6.
# Make sure that fping6 binary has root ownership and SUID flag set.
# Make empty if your fping utility is capable to process IPv6 addresses.
# Mandatory: no
# Default:
# Fping6Location=/usr/sbin/fping6
### Option: SSHKeyLocation
# Location of public and private keys for SSH checks and actions
# Mandatory: no
# Default:
# SSHKeyLocation=
### Option: LogSlowQueries
# How long a database query may take before being logged (in milliseconds).
# Only works if DebugLevel set to 3 or 4.
# 0 - don't log slow queries.
# Mandatory: no
# Range: 1-3600000
# Default:
# LogSlowQueries=0
### Option: TmpDir
# Temporary directory.
# Mandatory: no
# Default:
# TmpDir=/tmp
### Option: Include
# You may include individual files or all files in a directory in the configuration file.
# Installing Zabbix will create include directory in /usr/local/etc, unless modified during the compile time.
# Mandatory: no
# Default:
# Include=
# Include=/usr/local/etc/zabbix_server.general.conf
# Include=/usr/local/etc/zabbix_server.conf.d/
### Option: StartProxyPollers
# Number of pre-forked instances of pollers for passive proxies.
# Mandatory: no
# Range: 0-250
# Default:
# StartProxyPollers=1
### Option: ProxyConfigFrequency
# How often Zabbix Server sends configuration data to a Zabbix Proxy in seconds.
# This parameter is used only for proxies in the passive mode.
# Mandatory: no
# Range: 1-3600*24*7
# Default:
# ProxyConfigFrequency=3600
### Option: ProxyDataFrequency
# How often Zabbix Server requests history data from a Zabbix Proxy in seconds.
# Mandatory: no
# Range: 1-3600
# Default:
# ProxyDataFrequency=1
