zabbix history syncer processes more than 75 busy
  • joszif
    • Jan 2018
    Hi Kloczek,
    sorry but I'm newbie to storage performance issue.
    I installed fio and made random read and write performance tests. If I don't make a mistake the read/write ratio is 1/2.
    random read:
    bi@zabbix:/tmp$ fio --randrepeat=1 --ioengine=libaio --direct=1 --gtod_reduce=1 --name=test --filename=test --bs=4k --iodepth=64 --size=4G --readwrite=randread
    test: (g=0): rw=randread, bs=4K-4K/4K-4K/4K-4K, ioengine=libaio, iodepth=64
    fio-2.2.10
    Starting 1 process
    Jobs: 1 (f=1): [r(1)] [100.0% done] [6533KB/0KB/0KB /s] [1633/0/0 iops] [eta 00m:00s]
    test: (groupid=0, jobs=1): err= 0: pid=38667: Fri Feb 9 13:03:34 2018
    read : io=4096.0MB, bw=8550.2KB/s, iops=2137, runt=490554msec
    cpu : usr=0.76%, sys=2.61%, ctx=270801, majf=0, minf=73
    IO depths : 1=0.1%, 2=0.1%, 4=0.1%, 8=0.1%, 16=0.1%, 32=0.1%, >=64=100.0%
    submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
    complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.1%, >=64=0.0%
    issued : total=r=1048576/w=0/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0
    latency : target=0, window=0, percentile=100.00%, depth=64
    Run status group 0 (all jobs):
    READ: io=4096.0MB, aggrb=8550KB/s, minb=8550KB/s, maxb=8550KB/s, mint=490554msec, maxt=490554msec
    Disk stats (read/write):
    sda: ios=1058742/124229, merge=0/23899, ticks=32882792/272992, in_queue=33156740, util=100.00%
    random write:
    bi@zabbix:/tmp$ fio --randrepeat=1 --ioengine=libaio --direct=1 --gtod_reduce=1 --name=test --filename=test --bs=4k --iodepth=64 --size=4G --readwrite=randwrite
    test: (g=0): rw=randwrite, bs=4K-4K/4K-4K/4K-4K, ioengine=libaio, iodepth=64
    fio-2.2.10
    Starting 1 process
    Jobs: 1 (f=1): [w(1)] [100.0% done] [0KB/8516KB/0KB /s] [0/2129/0 iops] [eta 00m:00s]
    test: (groupid=0, jobs=1): err= 0: pid=48603: Fri Feb 9 14:03:33 2018
    write: io=4096.0MB, bw=4117.3KB/s, iops=1029, runt=1018716msec
    cpu : usr=0.36%, sys=1.49%, ctx=317704, majf=0, minf=9
    issued : total=r=0/w=1048576/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0
    WRITE: io=4096.0MB, aggrb=4117KB/s, minb=4117KB/s, maxb=4117KB/s, mint=1018716msec, maxt=1018716msec
    sda: ios=9362/1122857, merge=7/20915, ticks=1006788/54816900, in_queue=55825364, util=100.00%
    read/write:
    bi@zabbix:/tmp$ fio --randrepeat=1 --ioengine=libaio --direct=1 --gtod_reduce=1 --name=test --filename=test --bs=4k --iodepth=64 --size=4G --readwrite=randrw --rwmixread=75
    test: (g=0): rw=randrw, bs=4K-4K/4K-4K/4K-4K, ioengine=libaio, iodepth=64
    fio-2.2.10
    Starting 1 process
    Jobs: 1 (f=1): [m(1)] [100.0% done] [5966KB/1874KB/0KB /s] [1491/468/0 iops] [eta 00m:00s]
    test: (groupid=0, jobs=1): err= 0: pid=56500: Fri Feb 9 14:37:32 2018
    read : io=3071.7MB, bw=4857.5KB/s, iops=1214, runt=647541msec
    write: io=1024.4MB, bw=1619.9KB/s, iops=404, runt=647541msec
    cpu : usr=0.72%, sys=2.29%, ctx=444454, majf=0, minf=9
    issued : total=r=786347/w=262229/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0
    READ: io=3071.7MB, aggrb=4857KB/s, minb=4857KB/s, maxb=4857KB/s, mint=647541msec, maxt=647541msec
    WRITE: io=1024.4MB, aggrb=1619KB/s, minb=1619KB/s, maxb=1619KB/s, mint=647541msec, maxt=647541msec
    sda: ios=787076/417154, merge=0/45641, ticks=34827636/6285268, in_queue=41114504, util=100.00%
    joszif
    • bbrendon
      • Sep 2005
      • 873
      #17
      3.4.4 was killing me for some template issues and then 3.4.6 killed my disk.
      I'm hoping my problems are gone with 347rc1
      Here is a packaged version I made of 3.4.7rc1 using zabbix brand package rules.
      Unofficial Zabbix Expert
      Blog, Corporate Site
      • Breorn
        • Dec 2017
        History syncer and Housekeeper problem - v3.4.6
        Hello. Have the same problem too. Does anybody know, when v3.4.7 for RHEL 7 will be released? These issues really killing me. I really like Zabbix, but now I cannot use it as a primary oversight system, because it shows nonsenses (ZBX is overloaded and cannot process data to MariaDB). v3.4.4 was OK. Thanks a lot. There is v3.4.7 section in Zabbix manual, but this ver. is not present in official repo.
        • tcilmo
          • Nov 2016
          • 122
          #19
          Any estimates when 3.4.7 will be available?
          • tcilmo
            • Nov 2016
            • 122
            #20
            Re:
            Bbrendon,
            Will you please go into detail about what happened to your disk\environment when you were on 3.4.6?
            -Tony
            • tcilmo
              • Nov 2016
              • 122
              #21
              We were just told that Zabbix is going to prepare 3.4.7 packages early next week!
              • tcilmo
                • Nov 2016
                • 122
                #22
                Originally posted by kaspars.mednis
                3.4.5 and 3.4.6 are affected by
                that can be the cause of your issue
                Regards,
                Kaspars
                We were just told by Zabbix that the the bug (ZBX-13343) exists in all versions prior to 3.4.7.
                • bbrendon
                  • Sep 2005
                  • 873
                  #23
                  Originally posted by tcilmo
                  Bbrendon,
                  -Tony
                  It's detailed in the beginning of this thread by others.
                  • kloczek
                    • Jun 2006
                    • 1771
                    #24
                    Originally posted by joszif
                    Hi Kloczek,
                    random read:
                    fio-2.2.10
                    I've been asking you not to generate IO workload with such ratio but to have look at what is the ratio between read an write IOs generated by DB engine used by your zabbix server.
                    Do you have the monitoring of the IOs on this host?
                    • kacareu
                      • Feb 2018
                      Hi Kloczek,
                      joszif
                      Hi joszif,
                      What Kloczek implies is that you need to check write and read operation counts that are generated by Zabbix Server.
                      So you can use sysstat package for this purpose. For example;
                      iostat -x 2
                      ..output gives you r/s and w/s values for each disk in your system. Check the values and see the R/W ratio. You may post it here too, so we can check together.
                      • db100
                        • Feb 2023
                        • 62
                        #26
                        i have got a similar issue, however in my case the zabbix server is working quite smootlhy during regular operation, but as soon as it is restarted for some reason all processes go crazy ... here the metrics. is there a way to avoid this wild behavior ?
                        • db100
                          db100 commented
                          browsing through the forum i could find out that the history write cache seems to be the problem, you can see that going suddenly way up to 100 % ... i believe this might be due to some disk backpressure and/or cpu load ... but again i cant guess why this sudden change in behavior.
                          Would increasing the histroy_cache_size and the number of db_ / history_syncers solve this problem ?
