Guide that explains passive Zabbix agent executing a custom Bash script?
  • Sandra
    • Jun 2020
    • 10
    Dear all =)
    I would like to use the Zabbix Agent in passive mode, and have it execute the script /xabbix/check_example.sh every hour.
    Does anyone know of a guide that explains such a setup?
    Hugs
    Sandra =)
  • ysus
    • Mar 2016
    • 102
    I don't think such "guide" exists because everything explained in documentation.I guess the output of your "check_example.sh" is a simple value? In this case you have 2 options:
    1. Create new "UserParameter=foobar,/xabbix/check_example.sh" in "/etc/zabbix/zabbix_agentd.conf" file. Create new item of "Zabbix Agent" type with Key=foobar
    2. Move your "check_example.sh" to "/usr/lib/zabbix/externalscripts/" folder. Create new item of "External check" with Key=check_example.sh
    Set update interval of 1h for above item.
