Import initial schema and data
  • emort
    • Jun 2020
    Hello Zabbix people
    i'm trying to install Zabbix on a Raspberry pi and i am following the guide :https://www.zabbix.com/download?zabb...ysql&ws=apache
    under "import initial schema and data"
    i run the "zcat /usr/share/doc/zabbix-server-mysql*/create.sql.gz | mysql -u zabbix -p zabbix"
    and i'm prompted for the new password but afterwards nothing happens, only the "green" cursor appears.....
    What im i doing wrong?
    in advance THANKS!
  • emort
    • Jun 2020
    Did a clean Image
    waited ~ 10 min then ctrl +c and did the rest of the config.. seems to work now.
    • kloczek
      • Jun 2006
      • 1771
      How much do you have on oinnodb memory pool?
      Try to increase that memory if you did not change default (which is only 128MB)
      • emort
        • Jun 2020
        work fine with the waite, think it is very close to "limit" og Pi :-)
        • dsturzy
          • Oct 2020
          I am thinking that this could be a possible bug. I have ran into the exact same "hang" on multiple different pi's using multiple different SD cards. All on fresh buster installs (albeit the same image) . I too waited 15-20 min and do a reboot and continue on.
          • ZaBeast
            • Sep 2019
            • 42
            Depending on your Raspberry PI type and SD card speed, import can last from 1 minute to 3 hours (Rpi 2). Optimize raspberry with this guide and be patient when importing data.
