Trigger prototypes not sending notification or getting into problem dashboard
  • RomanoVroege
    • Jun 2020
    I have recently started with a new and fresh install of zabbix 5.0.
    Everything seems to be working correctly now but i would like to know if there is a option to get trigger prototypes to send notifications.
    What happens now is that the trigger prototype does create a trigger on the host i have assigned it to (for testing) with a sevarity of "Disaster"
    However there is only the trigger on the host that says "Disaster" but not in my problem dashboard or a notification.
    I also tried to change the actions and put the name of the trigger in there as action.
    Does somebody know what this is and how to get this working?
  • sparks5737
    • Apr 2021
    we have te same problem with Zabbix 4.2. The notification doesn't work for trigger prototypes.
    is some solution for it or workaround?
    Thank you.
    Tags: actions, discovery, trigger
