Get value from agent failed: ZBX_TCP_READ() failed: [104] Connection reset by peer
  • allen03
    • Jul 2020
    HI everyone,
    I 'm new on Zabbix 5.0, I first to try is monitoring a window server for passive mode with 10050 port,
    However, after installing the agent, it shows on the dashboard " Get value from agent failed: ZBX_TCP_READ() failed: [104] Connection reset by peer"
    I try to find the fix on the internet but seem none of them help .
    Does anyone even have the same problem and fixed finally.
    thanks
    Allen
  • Hamardaban
    • May 2019
    • 2714
    Check whether the agent is running and whether it is correctly configured to work with the network ( whether the port on the ip address listens) and whether the firewall allows such connections.
