Flapping
  • csmall
    • Jun 2020
    • 70
    Flapping
    What is the best way to deal with notifications and a problem that is flapping?
    For example I have a Ups with a battery temperature that is triggering and resolving over and over.
    The action sends an email each time resting in tons of emails.
    How do you address this sort of behavior?
  • csmall
    • Jun 2020
    • 70
    Would changing the trigger expression to fire if the value is happening for a duration of time? Like 10 minutes, then fire. That way if it flaps under the 10 minutes I wouldn't get an email
    • tim.mooney
      • Dec 2012
      • 1432
      The general answer is you avoid flapping/hysteresis by using careful trigger expressions and/or recovery expressions.
      If you want specific suggestions, you need to provide more information about your environment: what version of Zabbix you're using, what item you're collecting, what trigger(s) is/are involved (the full expression, you can obscure the hostnames), and whether there is a recovery expression and what it is if there is one.
