Remote command to restart zabbix server
  • joanaribeiro_erre
    • Jul 2020
    • 25
    Hi guys!
    i have an IBMi that every week goes through an IPL, which means a restart, this crashes the snmp connection and the only way it goes up again is with a restart to the zabbix server (restarting the service either in the zabbix side or in the ibmi side isn't enough).
    Has anyone had this type of problem? or similar?
    Thanks a lot!
  • Hamardaban
    • May 2019
    • 2714
    What version of SNMP do you use for monitoring? If v3-try switching to v2 and see if you need to restart the zabbix server?
    • joanaribeiro_erre
      • Jul 2020
      • 25
      Thank you for your suggestion, we are using v3, in this case v2 is not supported and v1 ends up being pointless
      • Hamardaban
        • May 2019
        • 2714
        It is possible that some hardware manufacturers do not fully comply with the SNMP standards, which leads to problems on the zabbix server side. Zabbix version 5 has a new runtime command:
        Manual SNMP cache clearing
        Zabbix server and Zabbix proxy now support an -R snmp_cache_reload runtime control option, which reloads the SNMP cache and clears the SNMP properties (engine time, engine boots, engine id, credentials) for all hosts. Net-SNMP version 5.3.0 or higher is required.
