Zabbix monitoring docker
  • kkpc
    • Aug 2020
    I needs to monitor container docker in the swarm, docker template works with agent 2, but as the container moves to the other host change name, add unique tag to name. Zabbix alerts that container does not exist.
    How can I monitor a container that changes name dynamically.
    thank you for help.
  • isaqueprofeta
    • Aug 2020
    • 154
    thank you for hellp.
    This concept is old and repetitive but Docker containers are ephemeral, they "short" live, they "fastly" die, and simply do not exist anymore peridot. My advice to you is to concentrate container data in a hybrid prometheus+lld vs Zabbix monitoring for the service, not for the container.
    When I work with Docker/Kubernetes I always keep in mind that a container is not a host.
    • kkpc
      • Aug 2020
      In the Items: #NAME :
      string returns:
      I just want it to be:
      without:
      how to remove it from the name?
      • isaqueprofeta
        • Aug 2020
        • 154
        string returns:
        without:
        For that, you can try preprocessing it: https://www.zabbix.com/documentation.../preprocessing
