Installing Proxy from Repo packages
  • msilberman
    • Dec 2014
    I'm trying to install the Zabbix Proxy and get a dependency message for zabbix-proxy-implementation.
    # rpm -ivh http://repo.zabbix.com/zabbix/2.4/rh...el6.x86_64.rpm
    Retrieving http://repo.zabbix.com/zabbix/2.4/rh...el6.x86_64.rpm
    warning: /var/tmp/rpm-tmp.lZfLpG: Header V4 DSA/SHA1 Signature, key ID 79ea5ed4: NOKEY
    error: Failed dependencies:
    libmysqlclient.so.16()(64bit) is needed by zabbix-proxy-mysql-2.4.4-1.el6.x86_64
    libmysqlclient.so.16(libmysqlclient_16)(64bit) is needed by zabbix-proxy-mysql-2.4.4-1.el6.x86_64
    zabbix-proxy = 2.4.4-1.el6 is needed by zabbix-proxy-mysql-2.4.4-1.el6.x86_64
    warning: /var/tmp/rpm-tmp.AYmjJX: Header V4 DSA/SHA1 Signature, key ID 79ea5ed4: NOKEY
    zabbix-proxy-implementation = 2.4.4-1.el6 is needed by zabbix-proxy-2.4.4-1.el6.x86_64
    Which RPM package do I need for zabbix-proxy-implementation?
    Regards,
    Michael
  • Jason
    • Nov 2007
    • 431
    You're probably best adding the repository to your system and then using yum to install it so it can automatically pull in all the dependencies.
