array_combine() Error when Creating a Host
  • karl_009
    • Feb 2015
    • 12
    Unsure if this is causing an issue in the background, I have setup a new Zabbix installation on CentOS 6.6 when I go to create a new host I have the following message along the bottom;
    array_combine(): Both parameters should have at least 1 element [hosts.php:794 → CView->render() → include() → array_combine() in /usr/share/zabbix/include/views/configuration.host.edit.php:201]
    Any ideas, have I missed something during the install, I have installed Zabbix a few times now but never seen this.
    Karl
  • leeman24
    • Mar 2015
    I am getting the exact same issue and error code on CentOS 6.6.
    I built from source. I manually found the missing libraries on ./configure errors.
    Let me know if you ended up finding anything.
