Connection to Zabbix-MySql with PowerBi
  • AxelFcF
    • Sep 2020
    Hello everybody,
    I want to build a reporting-dashboard in PowerBi, which shows the status of our computers with the zabbix-client. A goal would be a geographic map, with dots for the individual clients-condition.
    I was able to connect to the MySql "Zabbix"-database, but i cant figure out, where to look for the information i need. Because there are a bunch of tables, with ambiguous names.
    "hostid" seems to be the identifier of the client, but where can i find the status reports to map with the hostid.
    I would be very grateful, for any hint in the right direction,
    Regards
    Axel
  • tim.mooney
    • Dec 2012
    • 1436
    Can PowerBI gather data via an authenticated web API? If it can, I think you would be better off pulling data from Zabbix via the API rather than accessing the database directly.
    • Rymouchka
      • Dec 2020
      Can you please tell me how did you integrate zabix to power bi ?
      thank you in advance
