mariadb cluster, haproxy and zabbix
  • BayramGrbz45
    • Sep 2020
    • 16
    I'm trying to run Zabbix with haproxy, keepalived, mariadb and galera cluster. Can you help me?
    3 mariadb cluster databse server.
    2 keepalıvad and haproxy server.
    1 zabbix server.
    log;
    Error in query [COMMIT] [Deadlock found when trying to get lock; try restarting transaction]
    log2;
    Sep 28 13:59:41 db2 mysqld[18273]: 2020-09-28 13:59:41 101 [Warning] Aborted connection 101 to db: 'mydb' user: 'myuser' host: '192.168.1.107' (Got an error reading communication packets)
    log3;
    Sep 28 14:01:58 hake haproxy[16785]: 192.168.1.103:37036 [28/Sep/2020:14:01:58.229] galera_cluster_frontend galera_cluster_backend/db2 1/1/8 295 -- 14/14/13/4/0 0/0
    Sep 28 14:01:59 hake haproxy[16785]: 192.168.1.103:36960 [28/Sep/2020:14:01:09.283] galera_cluster_frontend galera_cluster_backend/db1 1/0/50008 364 cD 13/13/12/4/0 0/0
    Sep 28 14:01:59 hake haproxy[16785]: 192.168.1.103:37038 [28/Sep/2020:14:01:59.492] galera_cluster_frontend galera_cluster_backend/db3 1/0/27 2550 -- 14/14/13/4/0 0/0
    log4;
    Sep 28 14:05:29 hake Keepalived_vrrp[19536]: Opening file '/etc/keepalived/keepalived.conf'.
    Sep 28 14:05:29 hake Keepalived_vrrp[19536]: WARNING - default user 'keepalived_script' for script execution does not exist - please create.
    Sep 28 14:05:29 hake Keepalived_vrrp[19536]: Truncating auth_pass to 8 characters
    Sep 28 14:05:29 hake Keepalived_vrrp[19536]: SECURITY VIOLATION - scripts are being executed but script_security not enabled.
    Sep 28 14:05:29 hake Keepalived_vrrp[19536]: Using LinkWatch kernel netlink reflector...
    Sep 28 14:05:29 hake Keepalived_vrrp[19536]: VRRP_Script(chk_haproxy) succeeded
    Sep 28 14:05:30 hake Keepalived_vrrp[19536]: VRRP_Instance(LB_VIP) Transition to MASTER STATE
    Sep 28 14:05:30 hake Keepalived_vrrp[19536]: VRRP_Instance(LB_VIP) Changing effective priority from 101 to 103
    Sep 28 14:05:31 hake Keepalived_vrrp[19536]: VRRP_Instance(LB_VIP) Entering MASTER STATE
    Sep 28 14:05:31 hake Keepalived_vrrp[19536]: SMTP connection ERROR to [127.0.0.1]:25.
