/home/virtfs on Cpanel discovery virtfs comes as filesystem
  • akarim
    • Aug 2008
    • 33
    Hi.
    I'm looking for this problem and only a post on 2012 without response.
    File systems for discovery get each /home/virtfs/<user> how a filesystem.
    I don't see any system for create a rule, for not "discover" this jailed virtual filesystem.
    Apreciate help.
    Zabbix 2.4 on server and hosts
  • coreychristian
    • Jun 2012
    • 159
    Assuming I am reading this correctly, you essentially want to exclude some file systems based on the mount point name (or possibly FS Type)?
    For name, you would need to create a second filter on your discovery, and have your discovery item use the second regular expression similar to the first.
    For FS Type you should be able to edit the default regular expression.
    • akarim
      • Aug 2008
      • 33
      A lot of thanks.
      Despite about process. Try several ways, but not work.
      1. Create regular expression "Excluir virtfs"
      2. /virtfs/ Result is FALSE Yes
      3. Test expresion. If /virtfs/ it's on name filesystem, expresion it's false
      4. /virtfs/ Result is FALSE FALSE
      5. On discovery rule AND original rule, and new rule {#FSNAME} @Excluir vrtfs
      After some time, not discover any filesystem.
      • akarim
        • Aug 2008
        • 33
        Solved
        Thanks.
        After 1 hour work fine.
