v5.0.3 (revision 146855bff3) CentOs + Mysql 8: engine startup problem
02-10-2020, 09:59
Hello.
I am in the process of setting up an integration environment in v5.0.3 separate on 3 VMs (1 engine, 1 frontend, 1 DB).
The DB server is functional and configured with bin + user zabbix scripts with all rights. I can connect to it through other servers.
password change in mysql_native_password mode
The frontend server is functional and configured with Zabbix binaries
The engine server is installed and configured. The engine server have mysql-client installed
Except that when I try to turn on the engine I have a knockout: (log level 4)
(Partial) parameters of zabbix_server.conf:
Do you have an idea ? Because the log is not very explicit.
Thank you.
02-10-2020, 09:59
Hello.
20845:20201002:094728.987 In DBconnect() flag:0 20845:20201002:094728.993 [Z3001] connection to database '[I]myDB[/I]' failed: [1044] Access denied for user 'zabbix'@'%' to database '[I]myDB[/I]' 20845:20201002:094728.993 Cannot connect to the database. Exiting...
DBHost=myDBip ### Option: DBName # Database name. # # Mandatory: yes # Default: # DBName= DBName=myDB ### Option: DBSchema # Schema name. Used for PostgreSQL. # # Mandatory: no # Default: # DBSchema= ### Option: DBUser # Database user. # # Mandatory: no # Default: # DBUser= DBUser=zabbix ### Option: DBPassword # Database password. # Comment this line if no password is used. # # Mandatory: no # Default: # DBPassword= DBPassword=myPWD ### Option: DBSocket # Path to MySQL socket. # # Mandatory: no # Default: # DBSocket= DBSocket=/database/mysql/myDB/myDB.sock ### Option: DBPort # Database port when not using local socket. # # Mandatory: no # Range: 1024-65535 # Default: # DBPort= DBPort=myport
Thank you.
