No CPU or Memory readings are being captured
  • texmansru47
    • Jan 2020
    Everything was working perfectly until we had a PM on our servers this past weekend. After that we received hundreds of alerts from Zabbix (version 5.0.3) then no captures of CPU or memory data from any devices. Will this take an agent upgrade or something?
  • AVP.Riga
    • Oct 2020
    • 59
    Could you please share zabbix_server.log?
    • texmansru47
      • Jan 2020
      Here is what I have. It will not let me attach the file: So here is a partial of the file... it is the same thing over and over again:
      1. Failed: cannot extract value from json by path "$[?(@.Name == "3")].CurrentDiskQueueLength.first()": no data matches the specified path
      2286:20201020:062239.543 error reason for "UTIL02:vfs.dev.queue_size[CurrentDiskQueueLength.2]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"0","AvgDiskBytesPerTran sfe r":"0","AvgDiskBytesPerWrite":"0","AvgDiskQueu. ..
      1. Failed: cannot extract value from json by path "$[?(@.Name == "2")].CurrentDiskQueueLength.first()": no data matches the specified path
      2286:20201020:062246.553 error reason for "FAC02:vfs.dev.write.rate[DiskWritesPersec.1]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"10396","AvgDiskBytesPer Tra nsfer":"41984","AvgDiskBytesPerWrite":"360727"...
      1. Failed: cannot extract value from json by path "$[?(@.Name == "1")].DiskWritesPersec.first()": no data matches the specified path
      2286:20201020:062246.553 error reason for "FAC02:vfs.dev.util[PercentDiskTime.1]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"10396","AvgDiskBytesPer Tra nsfer":"41984","AvgDiskBytesPerWrite":"360727"...
      1. Failed: cannot extract value from json by path "$[?(@.Name == "1")].PercentDiskTime.first()": no data matches the specified path
      2286:20201020:062246.553 error reason for "FAC02:vfs.dev.read.rate[DiskReadsPersec.1]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"10396","AvgDiskBytesPer Tra nsfer":"41984","AvgDiskBytesPerWrite":"360727"...
      1. Failed: cannot extract value from json by path "$[?(@.Name == "1")].DiskReadsPersec.first()": no data matches the specified path
      2286:20201020:062246.554 error reason for "FAC02:vfs.dev.queue_size[CurrentDiskQueueLength.1]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"10396","AvgDiskBytesPer Tra nsfer":"41984","AvgDiskBytesPerWrite":"360727"...
      1. Failed: cannot extract value from json by path "$[?(@.Name == "1")].CurrentDiskQueueLength.first()": no data matches the specified path
      2285:20201020:062248.558 error reason for "BKUP05:vfs.dev.write.rate[DiskWritesPersec.1 I:]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"0","AvgDiskBytesPerTran sfe r":"0","AvgDiskBytesPerWrite":"0","AvgDiskQueu. ..
      1. Failed: cannot extract value from json by path "$[?(@.Name == "1 I:")].DiskWritesPersec.first()": no data matches the specified path
      2285:20201020:062248.558 error reason for "BKUP05:vfs.dev.util[PercentDiskTime.1 I:]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"0","AvgDiskBytesPerTran sfe r":"0","AvgDiskBytesPerWrite":"0","AvgDiskQueu. ..
      1. Failed: cannot extract value from json by path "$[?(@.Name == "1 I:")].PercentDiskTime.first()": no data matches the specified path
      2285:20201020:062248.558 error reason for "BKUP05:vfs.dev.queue_size[CurrentDiskQueueLength.1 I:]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"0","AvgDiskBytesPerTran sfe r":"0","AvgDiskBytesPerWrite":"0","AvgDiskQueu. ..
      1. Failed: cannot extract value from json by path "$[?(@.Name == "1 I:")].CurrentDiskQueueLength.first()": no data matches the specified path
      2285:20201020:062248.558 error reason for "BKUP05:vfs.dev.write.rate[DiskWritesPersec.3 D:]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"0","AvgDiskBytesPerTran sfe r":"0","AvgDiskBytesPerWrite":"0","AvgDiskQueu. ..
      1. Failed: cannot extract value from json by path "$[?(@.Name == "3 D:")].DiskWritesPersec.first()": no data matches the specified path
      2285:20201020:062248.558 error reason for "BKUP05:vfs.dev.read.rate[DiskReadsPersec.3 D:]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"0","AvgDiskBytesPerTran sfe r":"0","AvgDiskBytesPerWrite":"0","AvgDiskQueu. ..
      1. Failed: cannot extract value from json by path "$[?(@.Name == "3 D:")].DiskReadsPersec.first()": no data matches the specified path
      2285:20201020:062248.558 error reason for "BKUP05:vfs.dev.read.rate[DiskReadsPersec.2 J:]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"0","AvgDiskBytesPerTran sfe r":"0","AvgDiskBytesPerWrite":"0","AvgDiskQueu. ..
      1. Failed: cannot extract value from json by path "$[?(@.Name == "2 J:")].DiskReadsPersec.first()": no data matches the specified path
      2285:20201020:062248.558 error reason for "BKUP05:vfs.dev.write.rate[DiskWritesPersec.2 J:]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"0","AvgDiskBytesPerTran sfe r":"0","AvgDiskBytesPerWrite":"0","AvgDiskQueu. ..
      1. Failed: cannot extract value from json by path "$[?(@.Name == "2 J:")].DiskWritesPersec.first()": no data matches the specified path
      2285:20201020:062248.558 error reason for "BKUP05:vfs.dev.read.rate[DiskReadsPersec.1 I:]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"0","AvgDiskBytesPerTran sfe r":"0","AvgDiskBytesPerWrite":"0","AvgDiskQueu. ..
      1. Failed: cannot extract value from json by path "$[?(@.Name == "1 I:")].DiskReadsPersec.first()": no data matches the specified path
      2285:20201020:062248.558 error reason for "BKUP05:vfs.dev.util[PercentDiskTime.3 D:]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"0","AvgDiskBytesPerTran sfe r":"0","AvgDiskBytesPerWrite":"0","AvgDiskQueu. ..
      1. Failed: cannot extract value from json by path "$[?(@.Name == "3 D:")].PercentDiskTime.first()": no data matches the specified path
      2285:20201020:062248.558 error reason for "BKUP05:vfs.dev.util[PercentDiskTime.2 J:]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"0","AvgDiskBytesPerTran sfe r":"0","AvgDiskBytesPerWrite":"0","AvgDiskQueu. ..
      1. Failed: cannot extract value from json by path "$[?(@.Name == "2 J:")].PercentDiskTime.first()": no data matches the specified path
      2285:20201020:062248.558 error reason for "BKUP05:vfs.dev.queue_size[CurrentDiskQueueLength.3 D:]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"0","AvgDiskBytesPerTran sfe r":"0","AvgDiskBytesPerWrite":"0","AvgDiskQueu. ..
      1. Failed: cannot extract value from json by path "$[?(@.Name == "3 D:")].CurrentDiskQueueLength.first()": no data matches the specified path
      2285:20201020:062248.558 error reason for "BKUP05:vfs.dev.queue_size[CurrentDiskQueueLength.2 J:]" changed: Preprocessing failed for: [{"AvgDiskBytesPerRead":"0","AvgDiskBytesPerTran sfe r":"0","AvgDiskBytesPerWrite":"0","AvgDiskQueu. ..
      1. Failed: cannot extract value from json by path "$[?(@.Name == "2 J:")].CurrentDiskQueueLength.first()": no data matches the specified path
      2293:20201020:062311.457 Zabbix agent item "wmi.getall[root\cimv2,"select * from win32_perfformatteddata_perfdisk_physicaldisk"]" on host "SRVR02" failed: first network error, wait for 15 seconds
      2292:20201020:062312.009 Zabbix agent item "wmi.getall[root\cimv2,"select * from win32_perfformatteddata_perfdisk_physicaldisk"]" on host "SRVR01" failed: first network error, wait for 15 seconds
      2296:20201020:062326.125 resuming Zabbix agent checks on host "SRVR02": connection restored
      2296:20201020:062327.408 resuming Zabbix agent checks on host "SRVR01": connection restored
      • AVP.Riga
        • Oct 2020
        • 59
        As I understand you have some issues with Preprocessing "Preprocessing failed for: " please check incoming data without preprocessing.
        Maybe you don't receive "on host "SRVR01" failed: first network error" anything and preprocessing don't have anything to work with.
        • texmansru47
          • Jan 2020
          Well, nothing really changed? The data was there just last week... it was only when the server patches were complete this broken. What preprocessing are you talking about?
          • AVP.Riga
            • Oct 2020
            • 59
            You can try to receive data manually? Do you receive anything from the host?
            • texmansru47
              • Jan 2020
              Only one problem... When I go to All Hosts-> Zabbix Server there is no preprocessing option under the Item option....
              • AVP.Riga
                • Oct 2020
                • 59
                Preprocessing is located into each Item.
                • texmansru47
                  • Jan 2020
                  Obviously I am doing something wrong but on the several screens I have search per host... there is no preprocessing option anywhere... I even did a find on each page for the word.... nothing.
                  • AVP.Riga
                    • Oct 2020
                    • 59
                    Do you receive any data from SRVR02, SRVR01? Don't forget add "Show details" mark.Click image for larger version
                    • texmansru47
                      • Jan 2020
                      I am getting the status light of the server and some notifications of disk space but nothing else.
