How to monitor logs on /var/log/secure location?
  • adrianzabvitz
    • Oct 2020
    • 10
    Hi, I want to know how could I monitor logs on the /var/log/secure location, I have created an Item an Trigger but It does not work and I do not know why, below is the images for the Item, trigger and I have also change the permissions on the server I want to monitor, I have added the zabbix user to the root group.
ID:	411805Click image for larger version
  • Atsushi
    • Aug 2013
    • 2028
    Check the file permissions. You wrote that you added the zabbix user to the root group, but does the file have permissions that allow it to be read by the root group?
    In my CentOS 8 environment, the file permissions are as follows, so I think that only the root user can read and write unless you change the permissions.
    # ls -l /var/log/secure
    -rw------- 1 root root 0 Oct 25 03:41 /var/log/secure
    • adrianzabvitz
      adrianzabvitz commented
      I have restarted the zabbix agent
    • Atsushi
      Atsushi commented
      Did you output a log that matches the character string specified in the regular expression?
    • adrianzabvitz
      Yes, the output matches the regular expression
