Cisco 3750 24 port Template
  • duchlik
    • Apr 2015
    Hi can anyone help me ?
    I'm looking for cisco 3750 template to monitor in and out on ports.
  • aib
    • Jan 2014
    • 1615
    Did you try to use a standard template "Template SNMP Interfaces" ?
    Sincerely yours,
    Aleksey
    • zerocool
      • Jul 2007
      • 33
      truly speaking from when I use the low level discovery (LLD) with SNMP, I do not need to have templates specifically for the switch Cisco or HP etc etc ...
      Attach my template with the hope that it will come in handy.
      Regards.
      • duchlik
        • Apr 2015
        Regards.
        I get this type of reply
        Cannot find value map "NetworkStatus" used for item prototype "{#SNMPVALUE} (interface) - Link Status" of discovery rule "Switch Interface" on "Template Switch Discovery Interface".
        • aib
          • Jan 2014
          • 1615
          Value map for "NetworkStatus" is the same as "SNMP interface status (ifOperStatus)"
          So, you can edit the template(Notepad/Notepad++/vi/nano) and replace one name to different.
          Then, try to import it again.
          Sincerely yours,
          Aleksey
          • Gsmith
            • Mar 2015
            • 56
            Just An Idea
            I used some of these>>
            I modified them to my own needs, Basically I made my own template took what I needed from there and discarded the rest. Hope that helps you out.
            -Gsmith
            • zerocool
              • Jul 2007
              • 33
              You are right.
              Add this "Value Mapping" into your server :
              "NetworkStatus"
              1 ⇒ up
              2 ⇒ down
              3 ⇒ testing
              4 ⇒ unknown
              5 ⇒ dormant
              6 ⇒ notPresent
              7 ⇒ lowerLayerDown
