Can a Zabbix Appliance be used in production?
  • RichD
    • Dec 2020
    I'm new to Zabbix and haven't used Linux in a while. Tutorials all show installing Zabbix on base Linux servers. Is there a reason not to use the Zabbix Appliance build running in the VM environment?
  • Hamardaban
    • May 2019
    • 2714
    This is not recommended.
    But it will work for a while. Then you will face a lack of space and the need to customize the system...
    • RichD
      • Dec 2020
      Can't the virtual appliance be expanded if that happens?
      Typically I can expand volumes, add vCPUs, and add RAM to virtual machines of they get low on resources.
      • provels
        • Apr 2020
        • 93
        True, I even ran out of space on my home install after a few months monitoring about 5 hosts. But it's great for getting your feet wet and teaching yourself how the darn thing works. I think out of the box, the appliance keeps a year of data and it's pretty busy. I dropped my data down to 90 days and that helped greatly and I doubt I'll ever got to a full install..
