How to set up measurement retention and monitoring interval
  • MatteoM
    • Dec 2020
    Hi there!
    I'm using zabbix to monitoring some docker containers.
    I want to set zabbix to keep the measurement data for each metric (for example memory usage, cpu total usage per second etc ...) for 12 months, how can I do it?
    Also I would like to change the time interval to do the monitoring of my containers, for example I would like the agent to check the containers every 5 minutes, also how can I do it?
    Thanks a lot for your answers.
  • troffasky
    • Jul 2008
    • 639
    History/Trend storage and update interval are all per-item parameters.
    • MatteoM
      • Dec 2020
      Thank you troffasky
