Change default values in Zabbix
  • XorroX
    • May 2015
    Hi Guys,
    We are using Zabbix 2.4.3.
    I am desperately searching for the way to change some default values:
    1. When creating a new host the value for "History storage period (in days)" should be set to 7 by default
    2. New graphs should automatically have ymin_type = fixed. Where can i change this?
    3. The "default message" and "recovery message" texts for actions should be changed
    Thank you for your help!
  • BDiE8VNy
    • Apr 2010
    • 680
    1) see getItemFormData() in forms.inc.php.
    2) see 'ymin_type' in graphs.php
                    else {
                            $data['width'] = getRequest('width', 900);
                            $data['height'] = getRequest('height', 200);
                    $data['ymin_type'] = getRequest('ymin_type', GRAPH_YAXIS_TYPE_CALCULATED);
                    $data['ymax_type'] = getRequest('ymax_type', GRAPH_YAXIS_TYPE_CALCULATED);
                    $data['yaxismin'] = getRequest('yaxismin', 0);
                    $data['yaxismax'] = getRequest('yaxismax', 100);
                    $data['ymin_itemid'] = getRequest('ymin_itemid', 0);
                    $data['ymax_itemid'] = getRequest('ymax_itemid', 0);
    • BDiE8VNy
      • Apr 2010
      • 680
      Argh! Due to:
      Too many live links/images found in your post content. Please edit your post or contact the administrator.
      another post:
      3) See 'ACTION_DEFAULT_MSG_TRIGGER' in defines.inc.php. When wanting a different recovery message, then see 'ACTION_DEFAULT_MSG_TRIGGER' (used for 'r_longdata') in actionconf.php
      • XorroX
        • May 2015
        Thanks Mate!
        Everything is working as it should
