Change Graph Widget Legend
  • markfree
    • Apr 2019
    • 875
    Hi.
    I'm using a graph widget to plot 3 item. I also added a fourth line with the sum of the 3 items.
    graph_with_sum
    This way the legend shows dataset sum and I cannot change that.
    Is there a way to change the legend's dataset names?
  • matmz
    • Mar 2021
    • 10
    Originally posted by markfree
    Hi.
    graph_with_sum
    Same problem here, have you solved it ?
    • markfree
      • Apr 2019
      • 875
      Nothing so far.
      • user1234
        • Jul 2022
        • 35
        I have exactly the same issue, any solution?
          Depends on version. 6.4 already has "data set label" option in graph widget.
