Zabbix 4.4 - Template DB MySQL - Account isn't read from agent conf
  • Frogg
    • Mar 2020
    • 18
    Hi, i know it is a recurent post about Mysql Template, but i didn't find any answer in other posts.
    So i am sorry after so many tries and researches i finally come there to try to find a solution for my trouble:
    The Mysql Server is distant (with zabbix agent) to zabbix server, and Zabbix server seems to try to connect with info server side instead of client side (zabbix agent) credentials
    1 - Environement
    Zabbix server version 4.4.6 (now updated to 5.2.4)
    Zabbix agent version 3.2.11
    Using agent on port 10050
    Template name Template DB MySQL (original not modified)
    Other templates are working well
    Server side
    appliance@zabbix:~$ zabbix_server --version
    zabbix_server (Zabbix) 5.2.4
    Revision e9f58de09c 25 January 2021, compilation time: Jan 7 2021 13:16:25
    Copyright (C) 2021 Zabbix SIA
    License GPLv2+: GNU GPL version 2 or later <http://gnu.org/licenses/gpl.html>.
    This is free software: you are free to change and redistribute it according to
    the license. There is NO WARRANTY, to the extent permitted by law.
    This product includes software developed by the OpenSSL Project
    for use in the OpenSSL Toolkit (http://www.openssl.org/).
    Compiled with OpenSSL 1.1.1f 31 Mar 2020
    Running with OpenSSL 1.1.1f 31 Mar 2020
    Client side
    └─ # zabbix_agentd --version
    zabbix_agentd (daemon) (Zabbix) 3.2.11
    Revision 76339 27 December 2017, compilation time: Dec 27 2017 15:13:43
    Copyright (C) 2017 Zabbix SIA
    2 - Configuration
    • zabbix-agent side: (agent has been restart after conf has been set)
    Added user to Mysql server credentials
    [FONT=Calibri][FONT=Consolas]CREATE USER 'zabbixagent'@'%' IDENTIFIED BY 'mypass';[/FONT][/FONT]
    [FONT=Calibri][FONT=Consolas]GRANT REPLICATION CLIENT,PROCESS,SHOW DATABASES,SHOW VIEW ON *.* TO 'zabbixagent'@'%';[/FONT][/FONT]
    [FONT=Calibri][FONT=Consolas]FLUSH PRIVILEGES;[/FONT][/FONT]
    Credentials added to .my.cnf (path /var/lib/zabbix checked in cat /etc/passwd | grep zabbix)
    [FONT=Calibri][FONT=Consolas]mkdir /var/lib/zabbix[/FONT][/FONT]
    [FONT=Calibri][FONT=Consolas]nano /var/lib/zabbix/.my.cnf[/FONT][/FONT]
    [FONT=Calibri][FONT=Consolas]chown -R zabbix:zabbix /var/lib/zabbix/[/FONT][/FONT]
    With content
    [FONT=Calibri][FONT=Consolas][client][/FONT][/FONT]
    [FONT=Calibri][FONT=Consolas]user='zabbixagent'[/FONT][/FONT]
    [FONT=Calibri][FONT=Consolas]password='mypass'[/FONT][/FONT]
    [FONT=Calibri][FONT=Consolas]socket=/var/lib/mysql/mysql.sock[/FONT][/FONT]
    The file
    /etc/zabbix/zabbix_agentd.d/userparameter_mysql.conf is present with content
    # For all the following commands HOME should be set to the directory that has .my.cnf file with password information.
    # Flexible parameter to grab global variables. On the frontend side, use keys like mysql.status[Com_insert].
    # Key syntax is mysql.status[variable].
    UserParameter=mysql.status[*],echo "show global status where Variable_name='$1';" | HOME=/var/lib/zabbix mysql -N | awk '{print $$2}'
    # Flexible parameter to determine database or table size. On the frontend side, use keys like mysql.size[zabbix,history,data].
    # Key syntax is mysql.size[<database>,<table>,<type>].
    # Database may be a database name or "all". Default is "all".
    # Table may be a table name or "all". Default is "all".
    # Type may be "data", "index", "free" or "both". Both is a sum of data and index. Default is "both".
    # Database is mandatory if a table is specified. Type may be specified always.
    # Returns value in bytes.
    # 'sum' on data_length or index_length alone needed when we are getting this information for whole database instead of a single table
    UserParameter=mysql.size[*],bash -c 'echo "select sum($(case "$3" in both|"") echo "data_length+index_length";; data|index) echo "$3_length";; free) echo "data_free";; esac)) from information_schem$
    UserParameter=mysql.ping,HOME=/var/lib/zabbix mysqladmin ping | grep -c alive
    UserParameter=mysql.version,mysql -V
    UserParameter=mysql.get_status_variables[*], mysql -h"$1" -P"$2" -sNX -e "show global status"
    UserParameter=mysql.db.discovery[*], mysql -h"$1" -P"$2" -sN -e "show databases"
    UserParameter=mysql.dbsize[*], mysql -h"$1" -P"$2" -sN -e "SELECT COALESCE(SUM(DATA_LENGTH + INDEX_LENGTH),0) FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA='$3'"
    UserParameter=mysql.replication.discovery[*], mysql -h"$1" -P"$2" -sNX -e "show slave status"
    UserParameter=mysql.slave_status[*], mysql -h"$1" -P"$2" -sNX -e "show slave status"
    • zabbix web interface:
    Host configuration
    added the template Template DB MySQL
    added the macro {$MYSQL.HOST} with value the IP of the Server with MySQL & zabbix-agent
    3 - Checks
    Web interface don't warn about no data collected for 30 min
    When i try the commands agent side they seems to works:
    zabbix_agentd -t "mysql.ping"
    mysql.ping [t|1]
    zabbix_agentd -t "mysql.status[Bytes_sent]"
    mysql.status[Bytes_sent] [t|212012265274]
    4 - Errors
    Zabbix agent side i have no errors
    Zabbix server side i have errors like zabbix server can't connect to mysql using wrong credential
    parser error : Start tag expected, '<' not found
    ERROR 1045 (28000): Access denied for user 'zabbix'@'server.host.name' (
    noname.xml:1: parser error : Start tag expected, '<' not found
    noname.xml:1: noname.xml:1: parser parser error : error : Start tag expected, '<' not found
    But i think it shoud not be zabbix but zabbix-agent from agent /var/lib/zabbix/.my.cnf
    And it should not be server.host.name (Host {HOST.DNS} or
    {HOST.NAME} ) but {$MYSQL.HOST} instead from macro
    If you have any idea about what i am doing wrong, thanks a lot in advance.
    ==> Finally SOLVED... the agent version must match a client version
  • tim.mooney
    • Dec 2012
    • 1437
    Hey Frogg, you did a very good job of providing background information about your setup and environment. I wish everyone that asked questions here did as well as you.
    I can't find a copy of the exact "Template DB MySQL" that you're using since the 5.x templates have changed (and improved!) greatly, so I can't be sure about this, but I have at least one idea.
    When you created the MySQL database user, you gave it a username of 'zabbix-agent'. I don't know if '-' is allowed in database usernames, but let's assume it is.
    I think it may be a problem that in the .my.cnf, you specified 'user=zabbix'. The 'user=' entry in .my.cnf should be the database user you want to default to using, so in your case, I think it should be 'zabbix-agent', not 'zabbix'.
    Also, if the template works the way I think it does, I think you could have used {$MYSQL.HOST} set to 'localhost'. I don't think that's the problem you're running into, but if you get it working after changing the user= in .my.cnf, might also be worth experimenting with {$MYSQL.HOST} set to localhost, and see if it still works. If it does, it might be worth switching to using that.
    • Frogg
      • Mar 2020
      • 18
      Hi Tim,
      Thanks for your answer.
      The template is the template in Zabbix 4.4 version by default.
      I changed "zabbix-agent" to "zabbixagent" (in config & mysql user) to check if "-" could cause a trouble
      But server side it still use 'zabbix'@'sub.domain.ext'
      It is an error in the post, in the conf file the user is the good one
      ERROR 1045 (28000): Access denied for user 'zabbix'@'localhost'
      if i set back the IP it user the domaine name of the server
      ERROR 1045 (28000): Access denied for user 'zabbix'@'sub.domain.ext'
      seems the user isn't read at all
      In the template description seems to be as i did:
      Requirements for template operation:
      1.Install Zabbix agent and MySQL client.
      2.Copy Template_DB_MySQL.conf into folder with Zabbix agent configuration (/etc/zabbix/zabbix_agentd.d/ by default). Don't forget restart zabbix-agent.
      3.Create MySQL user for monitoring. For example:
      CREATE USER 'zbx_monitor'@'%' IDENTIFIED BY '<password>';
      GRANT USAGE,REPLICATION CLIENT,PROCESS,SHOW DATABASES,SHOW VIEW ON *.* TO 'zbx_monitor'@'%';
      For more information read the MYSQL documentation https://dev.mysql.com/doc/refman/8.0/en/grant.html , please.
      4.Create .my.cnf in home directory of Zabbix agent for Linux (/var/lib/zabbix by default ) or my.cnf in c:\ for Windows. For example:
      [client]
      user=zbx_monitor
      password=<password>
      I even tried to remove the quotes
      [client]
      user=zabbixagent
      password=mypass
      Thanks anyway
      • Frogg
        • Mar 2020
        • 18
        So, i updated the server to Zabbix 5.2
        The template seems almost the same:
        zabbix_export:
        version: '5.2'
        date: '2021-01-28T22:39:18Z'
        groups:
        templates:
        template: 'Template DB MySQL'
        name: 'Template DB MySQL'
        description: |
        [client]
        user=zbx_monitor
        password=<password>
        There is something i dont understand:
        The serveur send the error:
        But isnt the agent who is collecting datas and should have the error ?
        Why the user is zabbix instead of user from .my.cnf ?
        Why server ip is change by it s DNS name ?
        I dont know where i could debug thoose informations
        I tried to:
        Update version to 5.2 > No success
        Open the port 3306 > No success
        Adding /var/lib/zabbix/.my.cnf server side > No success
        any help would be appreciated
        • Frogg
          • Mar 2020
          • 18
          Finally SOLVED... i t was the agent version, i updated to 5.2
          zabbix_agentd (daemon) (Zabbix) 5.2.4
          Revision e9f58de09c 25 January 2021, compilation time: Jan 25 2021 09:56:43
          Compiled with OpenSSL 1.0.2k-fips 26 Jan 2017
          Running with OpenSSL 1.0.2k-fips 26 Jan 2017
          In centos edit the file /etc/yum.repos.d/zabbix.repo
          And change the line (7 for centos 7change for your version ..., you can test the url in a browser)
          baseurl=http://repo.zabbix.com/zabbix/[B]5.2[/B]/rhel/7/$basearch/
          then launch the command
          yum upgrade zabbix-agent
          To verify agent version:
          • onlineramarao
            • Jul 2021
            If any issue with .my.cnf issue, please add that file in the Userparameter file itself. That will definetly read the file contents of user name and password.
            Ex:
            # view /usr/local/etc/zabbix5/zabbix_agentd.conf.d/template_db_mysql.conf
            UserParameter=mysql.ping[*], /usr/local/bin/mysqladmin --defaults-file=/usr/local/etc/zabbix5/.my.cnf ping
