Database (DB2 and MSSQL) monitoring - Zabbix Version 5 (5.0.7.)
  • DG-Zabbix
    • Feb 2021
    Hi folks,
    I am looking for suitable templates for monitoring a MSSQL database (running on Windows) and a DB2 (running on RedHat).
    I've come across several templates, but I'm not sure if they work for Zabbix 5 as well.
    Can you share your experiences or suggestions with me?
    Thanks a lot
    DG
  • yeffo
    • Nov 2020
    Originally posted by DG-Zabbix
    Hi folks,
    Thanks a lot
    DG
    Hi, did you find any solutions?
    Thx
    Jaro
    • gofree
      • Dec 2017
      • 400
      why not look first into zabbix integration portal ?
      at least offcial mssql support is there, db2 is there too ( community )
      • rkarpinski
        • Nov 2022
        gofree,
        did You look at these links before copy-paste? This db2 is currently not for db2 and it's unusable.
        • rkarpinski
          • Nov 2022
          Hi folks,
          Thanks a lot
          DG
          Did You find something to monitor DB2 database?
