Zabbix stopped working: Database error, connection refused
  • msdPeter
    • Feb 2021
    • 10
    over the weekend Zabbix stopped working. I installed the system two weeks ago, downloaded the VM appliance and added nearly 80 hosts. Today I´m back in office and the website didn´t open anymore as if the web service is gone. Then I logged onto the command console and restarted the system. Nothing happened, just a blinking cursor after the screen went black. Then turned off the power and added 4 extra GB RAM and changed the harddrive space from 10 to 25 GB. After a fresh boot the command console looks good but when I open the website I get an error:
    Database error - connection refused.
    What has happened and how can I get back into the website?
    Thanks for any help!
  • msdPeter
    • Feb 2021
    • 10
    I see... the harddrive went full... but how can this happen with a ready-to-go VM appliance? Trying to expand the hard drive now with gparted
    Got it... what helped is this tutorial:
    https://soundsessential.medium.com/z...d-2400981d7245
    Seems I´m not the only one running into this problem...
    • Hernandes Martins
      • Apr 2011
      • 901
      Look for this message: "You can use this Appliance to evaluate Zabbix. The Appliance is not intended for serious production use."
      Try install zabbix correctly to improve your experience.
      __
      Att.
      Skype: hernandss
      Telegram: @MrHernandes
      Español
      Português
      • msdPeter
        • Feb 2021
        • 10
        Ah, didn´t know that, thanks for the info!
