Hello!
I'm a Zabbix user for more than two years now, but only recently we decided to use IT Services to monitor our service's SLA.
I'm having an issue that I can't tell if it is a normal zabbix behavior or if it is some king of misconfiguration or error.
I have an IT Service called Application Server HA with two child IT Services:
- Server1 Ping;
- Server2 Ping.
Server1 Ping has a 50% SLA and Server2 Ping has a 100% SLA.
The SLA of the parent service (Application Server HA) is 99.6%.
I always believed that The parent SLA would only consider problems when the child SLA is being affected, but that is not the case. Even if the child SLA is OK, the Parent SLA is affected because of the different SLA's between them.
Shouldn't the parent SLA consider the child SLA instead of the child problems?
Thanks.
- Server1 Ping;
- Server2 Ping.
Thanks.
