info on importing hosts from zabbix version 1.8.2 to zabbix 5.2.5
  • pbzion
    • Mar 2021
    Hello everyone, I have an installation of zabbix 1.8.2 and I should import the hosts in a new installation of zabbix 5.2.5, from what I've read in the documentation seems that the XML files generated by version 1.8 are compatible, but as soon as I try to do the import on zabbix 5.2 I receive the error "Invalid tag "/zabbix_export/hosts/host(1)/items/item(1)": the tag "port" is missing.
    Do you think there is any possibility to do this operation with the standard tools of zabbix?
    thank you very much
    paolo
  • pbpm
    • Nov 2010
    Hi paolo,
    I've the same exact problem.
    If I'm not inappropriate​ how did you solve, if ever?
    And where did you find documentation about xml import/export. compatibility.
    Thanks (anyway..)
    Best regards
    pietro
      1.8 is a tad bit old to be converted directly... It should be possible to do from version 2.0.x. So maybe you take at first look on 1.8->2.0 upgrade and then follow 2.0 to 5.x.x upgrade?
      In any case, it is not a trivial task to skip so many versions and platform upgrade.. Good luck..:P
      Maybe it would be easier to create those hosts (and hostgroups etc) over API instead... ? At least gives you some ways to manipulate existing data and, if needed, do some conversions etc...
      • pbpm
        • Nov 2010
        cyber Many thanks for your gentle answer. I agree with you, it seems to be a little late to go from 1.8 to 5.x/6.x.
        I was just curious if someone had ever tried...
        And so, I'm very doubtful if - as you suggest - trying to read exported XML and feed it into new Zabbix via API or trying XML conversion (from XML exported from 1.8 to XML to be imported into a newer Zabbix)
        I have only to decide and engage myself in this work.. (I could seem a little lazy, I mean...)
        Thank you again for your attention and suggestions.
        However it will end, I'll try to share my results...
        P.
