VMware > automatically discovered virtual machine > group management
  • zabbix_user84
    • Jan 2021
    • 25
    Hello everybody,
    Could you tell me please, if it is possible to add a VM to a group when it is automatically discovered by the "VMware" template applied to a Vcenter.
    From what I see, after having edited the parameters of a VM, it is impossible to modify the groups because they are grayed out.
    Thanks in advance!
  • gofree
    • Dec 2017
    • 400
    Yes it is, you need to adjust discovery rules on template level - group prototypes - eg. its already adding VM to several groups ( v 5.2 - the same applied for older versions )
    • zabbix_user84
      • Jan 2021
      • 25
      Thank you for your reply. So if I understand correctly with your screenshot I will be able to assign another group to the virtual machines that will be discovered, but the problem is that it will be the same for all. I misunderstand?
      I would have liked to adapt the group manually as I would in normal times, when we create a host and associate it with a group.
      • gofree
        • Dec 2017
        • 400
        yes , same for all - but depends on the clustername, datacenter name, hypervisor name - so you get several groups for hypervisors, the same goes with datacenter, clustername - there is some order
        i think you can't manually change it
