Trigger only after multiple failures
  • barryr
    • May 2021
    I am trying to avoid triggering alarms unless the failure has happened 3 times sequentially. In this case if the temperature of some coolant is below 35C for three sequential occasions. The base code for a single failure is as follows.
    {Sensors1.ukdc1.dcops:bas700.set2.coolanttemp.last ()}<35
    Suggestions much appreciated
  • gofree
    • Dec 2017
    • 400
    check the docu - count function might work
      max value during 3 checks should be less than 35.
      {Sensors1.ukdc1.dcops:bas700.set2.coolanttemp.max( #3)}
