Zabbix Vault
  • Amiram
    • Feb 2021
    • 68
    Zabbix Vault
    I'm trying to setup my Zabbix Server to work with the new Vault system (supported since 5.2
    HTML Code:
    https://www.zabbix.com/documentation/5.2/manual/appendix/config/zabbix_server
    I'm trying to get my DB username and password from the vault server so I set up the three required params:
    • VaultDBPath
    • VaultToken
    • VaultURL
    After restarting the server service I'm getting the following error in the server log file:
    cannot initialize database credentials from vault: Cannot perform request: SSL certification problem: unable to get local issuer cerificate
  • Amiram
    • Feb 2021
    • 68
    Any idea here?
    • rcastro33
      • Oct 2021
      Hello Amiram,
      I had the same issue with a Docker deployment of Zabbix Server and Vault. Zabbix don't trust in self-signed certificates unless you allow it, adding a custom CA.
      What I've done is set the SSLCALocation parameter to a folder that has been prepared with my CA, using the Openssl c_rehash utility. I've copy the .pem certificate to that folder, and then use this utility.
      A note about this, is that the Common Name of the certificate must be valid, that means that must match the hostname. Otherwise, you can see a similar error:
      "cannot initialize database credentials from vault: Cannot perform request: SSL: certificate subject name 'nginx-docker' does not match target host name 'vault-nginx'"
      See https://www.zabbix.com/documentation...onfiguring-tls for more details.
      Good luck!
      • ramasamy
        • Dec 2021
        hi, does Zabbix request for new vault token when the value provided in "VaultToken" param expires?
        • Glencoe
          Zabbix developer
          • Oct 2019
          • 152
          No, it doesn't
          • ramasamy
            • Dec 2021
            hi, I'm facing another issue while trying to configure it with the enterprise vault
            Params provided in config:
            VaultToken=XXXXXXXXXXXXXXXXXX
            VaultURL=https://vault-dev.yourorg.com:8XXX
            VaultDBPath=secret/dev/00111111/zabbix
            Zabbix seems to be including 'data' in the path after 'secret', so I'm getting 403 permission denied error from the vault
            2031597:20220310:064707.659 In zbx_http_get() URL 'https://vault-dev.yourorg.com:8XXX/v1/secret/data/dev/00111111/zabbix'
            2031597:20220310:064707.697 End of zbx_http_get():SUCCEED
            2031597:20220310:064707.697 cannot initialize database credentials from vault: unsuccessful response code "403"
            • Glencoe
              Zabbix developer
              • Oct 2019
              • 152
              Zabbix includes "data" in accordance with Vault Secrets Engine v2 convention:
              Writing and reading versions are prefixed with the data/ path.
              (https://www.vaultproject.io/docs/secrets/kv/kv-v2)
              Perhaps you use Secrets Engine v1 which Zabbix does not support.
