Log monitoring for one hour
  • vitS
    • Apr 2021
    • 43
    I created item to search:
    log[/path/to/file,"is marked as crashed and should be repaired",,,,\1]
    Looks like it is working, but as I understood it will never resolve, because string is visible in file.
    How to create trigger to check log file only for last one hour.
    I tried last() - but it was unsuccessful.
    Maybe someone realized it already?
    Thanks,
  • vitS
    • Apr 2021
    • 43
    Thanks,
    Looks like working
      Log item reads from the last place, where it stopped. So your once found pattern will not be read again.
      Keeping trigger active for 1h can be done with nodata(1h)=0 expression.Trigger will be active until there is silence for 1h......
