Monitor my Zabbix agents
  • Vasuki
    • Jul 2020
    I'm new to Zabbix and in our infrastructure we have around 1200+ hosts being monitored under various networks. For example agents are deployed under same network, agents deployed under other network are also being monitored here. Because of complications few days some agents just stop working with either Interrupted system call or Connection refused and other errors. I know what has to be done to fix those issues but it's hard for me to check all 1200+ agents and make sure that they are communicating as expected. Is there any way I can setup an action or trigger which sends me an email of all my agent status? I need to an email which tells me if my agents is communicating and if not what is the error is it "Connection refused" or "Interrupted system call" or whatever might be the reason.
    Let me know if this is not clear I will try to give a more lengthy explanation.
