Zabbix repository mirror solution
  • markfree
    • Apr 2019
    • 875
    Hey guys.
    My production enviroment is under a firewall, I cannot access Internet from the Zabbix server itself.
    I'm looking for a solution to mirror Zabbix repository so I can update my server/proxy and host agents through it.
    Do you guys know any good way to mirror Zabbix repository? What solutions do you use?
  • markfree
    • Apr 2019
    • 875
    Just to update...
    I'm looking into Jfrog Artifactory.
    • tim.mooney
      • Dec 2012
      • 1436
      I usually manually fetch just the RPMs I need and then add them to a local yum repo, but for RPM-based systems there's also 'reposync'.
