Apologies if my formatting is off, this is my first post here.
I have been working on installing & implementing Zabbix on a server, using Hashicorp Vault to protect the DB credentials. After getting it installed (or so I thought), I proceeded to start enabling the actual server. The server is enabled and running through systemd, and tail-ing the server log file shows a number of lines like "server #x started", no errors in sight. When I go to the UI through the browser however, I get the error in the title and can't proceed.
When I perform these two tests (as described here https://www.zabbix.com/documentation...config/secrets),
They both output the values as expected, working fine.
After checking the token's capabilities, it has 'read' on both secret/database/zabbix and secret/data/zabbix/database
If it helps, here is the policy:
Here's the vault config options (with certain values cleaned)
Here's the server log:
I'm stumped as to what could be causing Zabbix to not be able to retrieve the DB credentials. If any more info is needed, please ask.
Thanks!
# Test that secret is successfully added $ vault kv get secret/zabbix/database # Finally test with Curl, note that "data" need to be manually added after mount point and "/v1" before the mount point, also see --capath parameter $ curl --header "X-Vault-Token: <Token specifically generated for zabbix>" https://127.0.0.1:8200/v1/secret/data/zabbix/database
path "secret/zabbix/database" {
capabilities = ["read"]
path "secret/data/*" {
### Option: VaultToken # Vault authentication token that should have been generated exclusively for Zabbix server with read only permission # to paths specified in Vault macros and read only permission to path specified in optional VaultDBPath # configuration parameter. # It is an error if VaultToken and VAULT_TOKEN environment variable are defined at the same time. # # Mandatory: no # Default: VaultToken=<previously mentioned token> ### Option: VaultURL # Vault server HTTP[S] URL. System-wide CA certificates directory will be used if SSLCALocation is not specified. # # Mandatory: no # Default: VaultURL=http://127.0.0.1:8200 ### Option: VaultDBPath # Vault path from where credentials for database will be retrieved by keys password and username. # Example: secret/zabbix/database # This option can only be used if DBUser and DBPassword are not specified. # # Mandatory: no # Default: VaultDBPath=secret/zabbix/database
131310:20210629:185915.036 Starting Zabbix Server. Zabbix 5.4.1 (revision ecb5b3378c). 131310:20210629:185915.036 ****** Enabled features ****** 131310:20210629:185915.036 SNMP monitoring: YES 131310:20210629:185915.037 IPMI monitoring: YES 131310:20210629:185915.037 Web monitoring: YES 131310:20210629:185915.037 VMware monitoring: YES 131310:20210629:185915.037 SMTP authentication: YES 131310:20210629:185915.037 ODBC: YES 131310:20210629:185915.037 SSH support: YES 131310:20210629:185915.037 IPv6 support: YES 131310:20210629:185915.037 TLS support: YES 131310:20210629:185915.037 ****************************** 131310:20210629:185915.037 using configuration file: /etc/zabbix/zabbix_server.conf 131310:20210629:185915.045 current database version (mandatory/optional): 05040000/05040000 131310:20210629:185915.046 required mandatory version: 05040000 131310:20210629:185915.052 server #0 started [main process] 131312:20210629:185915.052 server #1 started [configuration syncer #1] 131313:20210629:185915.153 server #2 started [housekeeper #1] 131314:20210629:185915.154 server #3 started [timer #1] 131315:20210629:185915.154 server #4 started [http poller #1] 131319:20210629:185915.156 server #8 started [history syncer #3] 131321:20210629:185915.157 server #10 started [escalator #1] 131322:20210629:185915.158 server #11 started [proxy poller #1] 131325:20210629:185915.159 server #14 started [poller #1] 131335:20210629:185915.169 server #24 started [trapper #5] 131328:20210629:185915.170 server #17 started [poller #4] 131337:20210629:185915.180 server #26 started [alert manager #1] 131329:20210629:185915.181 server #18 started [poller #5] 131317:20210629:185915.181 server #6 started [history syncer #1] 131316:20210629:185915.181 server #5 started [discoverer #1] 131330:20210629:185915.192 server #19 started [unreachable poller #1] 131323:20210629:185915.196 server #12 started [self-monitoring #1] 131324:20210629:185915.197 server #13 started [task manager #1] 131318:20210629:185915.197 server #7 started [history syncer #2] 131320:20210629:185915.197 server #9 started [history syncer #4] 131326:20210629:185915.198 server #15 started [poller #2] 131334:20210629:185915.199 server #23 started [trapper #4] 131338:20210629:185915.201 server #27 started [alerter #1] 131340:20210629:185915.201 server #29 started [alerter #3] 131345:20210629:185915.204 server #34 started [lld manager #1] 131349:20210629:185915.204 server #38 started [history poller #1] 131336:20210629:185915.205 server #25 started [icmp pinger #1] 131332:20210629:185915.206 server #21 started [trapper #2] 131327:20210629:185915.209 server #16 started [poller #3] 131347:20210629:185915.216 server #36 started [lld worker #2] 131351:20210629:185915.216 server #40 started [history poller #3] 131353:20210629:185915.218 server #42 started [history poller #5] 131333:20210629:185915.225 server #22 started [trapper #3] 131331:20210629:185915.235 server #20 started [trapper #1] 131339:20210629:185915.247 server #28 started [alerter #2] 131341:20210629:185915.247 server #30 started [preprocessing manager #1] 131343:20210629:185915.248 server #32 started [preprocessing worker #2] 131344:20210629:185915.248 server #33 started [preprocessing worker #3] 131346:20210629:185915.248 server #35 started [lld worker #1] 131348:20210629:185915.249 server #37 started [alert syncer #1] 131350:20210629:185915.249 server #39 started [history poller #2] 131352:20210629:185915.250 server #41 started [history poller #4] 131354:20210629:185915.251 server #43 started [availability manager #1] 131342:20210629:185915.306 server #31 started [preprocessing worker #1]
Thanks!
