Zabbix doesn't get the entire json from RabbitMQ queues
  • maar
    • Jul 2020
    I'm using the default template - RabbitMQ node by HTTP. The data collecting is working properly, but the output from queues seems to be not full.
    And because of that I can't parse the json and I don't have the all data.
    Are there any limits about length of output? Maybe it's about timeout? I set it to 60 in RabbitMQ: Get queues item and It's the maximum value:
    Invalid parameter "/timeout": value must be one of 1-60.
