Zabbix localization
  • davidmartib
    • Jun 2021
    Zabbix localization
    Dear forum,
    Perhaps this is a very basic question and is answered somewhere, but I'm unable to find it: My Zabbix is installed from the binary packages (not from the source) and I want to translate certain messages to my mother language. I've installed the system localesand I thin, configured the include locale file and the translated messages seems to be on the locale folder (mo files?). But if I try to edit this po file with, for exemple, poedit for mac, I always received a BAD GATEWAY from my nginx web server ... I need to replace the generated mo file with the original one to continue to work ...
    Any help or tutorial from where I can learn how to translate messages from English to my mother language?
    Thanks in advance for your help!
  • Atsushi
    • Aug 2013
    • 2028
    What steps did you take to be a little more specific? Did you get the source and use add_new_language.sh to add a directory for the new language?
    https://git.zabbix.com/projects/ZBX/...owse/ui/locale
    • davidmartib
      • Jun 2021
      Hi Atsushi , thanks for your reply.
      No, I didn't get the source ... I only install the locales I need on my system with dpkg-reconfigure locales and edit /usr/share/zabbix/include/locales.inc.php
      Thanks.
      • davidmartib
        • Jun 2021
        ok, now I've downloaded the po file for my locale, but the problem is the same ... I've updated the po files with some translations I need and then, with update_po.sh I've updated the corresponding po file. If I go to Zabbix, I received a 502 Bad Gateway from nginx ...
        • Atsushi
          • Aug 2013
          • 2028
          First, how did you create the directory or po file? Did you use add_new_language.sh?
          Also, did you run make_mo.sh and restart php-fpm after editing the po file?
          • davidmartib
            • Jun 2021
            Thank you very much Atsushi , restarting php-fpm do the trick!
