Zabbix server is not running
  • miramira007
    • Sep 2015
    • 89
    Dear Zabbix-Users,
    I'm new in the world of Zabbix, i installed Zabbix 2.4.6 on CentOS 7 Server with the step-by-step induractionhttps://www.zabbix.org/wiki/InstallOnCentOS_RHEL. It works fine, until i started the zabbix Web-Userinteface. Now i have an error. It tells me this here on the dashboard "Zabbix server is not running"
    i looked up in my zabbix_agentd.conf:
    no active checks on server [127.0.0.1:10051]: host [Zabbix server] is not monitored.
    But i have installed the agent and run it via
    rpm --import http://repo.zabbixzone.com/centos/RP...KEY-zabbixzone
    rpm -Uv http://repo.zabbixzone.com/centos/za...0-1.noarch.rpm
    yum install zabbix-agent -y
    chkconfig zabbix-agent on
    mv /etc/zabbix/zabbix_agentd.conf /etc/zabbix/zabbix_agentd.default
    sed 's/Server=127.0.0.1/Server=XXX.XXX.XXX.XXX/' /etc/zabbix/zabbix_agentd.default > /etc/zabbix/zabbix_agentd.conf
    service zabbix-agent start
    and my zabbix_server.conf tells me the same log file end "cannot send list if active checks to [127.0.0.1] host not monitored"
    i havent got an idea to resolve it.
    i need your help.
    thank you.
    mira
  • eaglelukash
    • Aug 2015
    The problem is that by default, SELinux prevents apache/php from connecting to network ports, even on localhost. To fix this, you must allow the SELinux rule: httpd_can_network_connect. You can try run this command:
    setsebool -P httpd_can_network_connect=true
    • jamesNJ
      • Jun 2015
      • 103
      If it is an internal server and selinux is not needed, you can also disable it in the boot file /etc/sysconfig/selinux. Debugging selinux is a real headache, especially if you don't need to use it on an internal server.
      • miramira007
        • Sep 2015
        • 89
        Thank you for the comments,
        but i disabled SElinux from the beginning. So this cant be the problem.
        Any ideas?
        • Hernandes Martins
          • Apr 2011
          • 901
          check the log and post the output of the following command
          tail -f /var/log/zabbix/zabbix_server.log
          __
          Att.
          Skype: hernandss
          Telegram: @MrHernandes
          Español
          Português
