Zabbix ICMP Host availability
  • carnevale
    • Jul 2021
    I found exactly what I want to do in the thread: Displaying the ICMP status of a hosts - ZABBIX Forums
    But it is only compatible with older versions (not 5.4).
    Is there any reason for the product don't support ICMP as interface and be able to update the host availability ?
    Is there way using SNMP interface (without having a service running in monitored device, and a trigger that can based on ICMP response flip the host availability ? If so can you please share the trigger expression ?
  • Hamardaban
    • May 2019
    • 2714
    You misunderstand the essence of the system's operation - the display of the interface state has an auxiliary value.
    The main work is based on triggers.
    • bitmeup
      • Apr 2018
      • 18
      That reply ignores the fact that the current design contributes negatively to glanceability and signal-to-noise ratio.
      For anyone that is having this issue, see post Zabbix Feedback for alpha and beta versions in the thread linked by the original poster
      • bitmeup
        • Apr 2018
        • 18
        I meant to post the link to my post, not sure what happened in post #3
        • myazdian
          • Jul 2022
          Hello guys,
          I am trying to add ICMP availability on Zabbix frontend 6.2. It seems some files have been changed from an older version. Has anyone worked on ICMP availability on frontend 6.2?
          Thank You
          • bitmeup
            • Apr 2018
            • 18
            Originally posted by myazdian
            Hello guys,
            Thank You
            You probably wanted to ask/comment in the other thread, where Hamardaban mentioned that he was no longer maintaining that feature
