Simple PING/ICMP check
  • mihab
    • Sep 2015
    • 13
    Hi
    Can anyone please explain me (step-by-step for dimmies :-)) how to confiugre Zabbix appliance for simple ICMP check ?
    I have configured e-mail and SMTP settings, but can't find how to configure host (when adding a new host there is only option for adding IP for agent monitoring ?
    I want to achieve that Zabbix will monitor one host (without agent) with simple ICMP:
    - sending ping in time interval of 5 minutes to a certain IP
    - if there is no ICMP response, Zabbix will send me an e-mail
    How can these be configured, what are the steps to do this ?
    Thank you all in advance for helping !
    Mike
  • teskistajer
    • Sep 2015
    • 19
    hi which steps did you able to make it.can you able to send a simple icmp ping on zabbix ? did you ask for only sending mail ? be more specifig please
    • mihab
      • Sep 2015
      • 13
      I didn't do anything. I tried to add a host but can't add IP since it wants me to add ip for monitoring during zabbix agent.
      I just need to add a host that need to be monitored via ICMP and sends me an email when this host is not reachable ?
      • Hernandes Martins
        • Apr 2011
        • 901
        Hi
        Look my basic tutorial how to monitoring with simple check.
        __
        Att.
        Skype: hernandss
        Telegram: @MrHernandes
        Español
        Português
        • mihab
          • Sep 2015
          • 13
          Hi
          Thank you this video helped me to get this working.
          I have another problem, warning are displayed on monitor but e-mails are not sent to configured users. I did all as described in manual, but under Events-Action I see under Actions status FAILED.
          • Husabuse
            • Aug 2015
            • 18
            I've looked at the video, and followed various guides how to get it working, sorted out the
            shell> chown root:zabbix /usr/sbin/fping
            shell> chmod 4710 /usr/sbin/fping
            Also check, if user zabbix belongs to group zabbix by running:
            shell> groups zabbix
            from https://www.zabbix.com/documentation.../simple_checks
            groups zabbix throws zabbix : zabbix
            And, I know that fping/6 resides under /usr/sbin...
            Still the log tells me that "at least one of '/usr/sbin/fping', '/usr/sbin/fping6' must exist. Both are missing in the system.
            (and fping works from the shell, and the server has been restarted numerous times)
            • Husabuse
              • Aug 2015
              • 18
              ...and the answer is here.
              The group name is zabbixs....in my prepackaged virtual appliance.
              FFS...
              • Hernandes Martins
                • Apr 2011
                • 901
                Mihab,
                please, create new thread for Actions status FAILED ok
                __
                Att.
                Skype: hernandss
                Español
                Português
