Custom message and "Disk read/write request responses are too high"
  • catkins
    • Feb 2020
    • 19
    Our Zabbix 5.0 custom message is
    Host: {HOST.NAME}
    Severity: {EVENT.SEVERITY}
    Problem started at {EVENT.TIME} on {EVENT.DATE}
    Problem name: {EVENT.NAME}
    Item: {ITEM.NAME}
    Item value: {ITEM.VALUE}
    Original problem ID: {EVENT.ID}
    That works well for most triggers but is misleading for "Template OS Linux by Zabbix agent active"'s "Disk read/write request responses are too high" trigger. Example
    Host: storage4.iciti.av
    Severity: Warning
    Problem started at 03:40:47 on 2021.08.28
    Problem name: sdc: Disk read/write request responses are too high (read > 20 ms for 15m or write > 20 ms for 15m)
    Item: sdc: Disk read request avg waiting time (r_await)
    Item value: 1.74 ms Original problem ID: 319756
    It was the write request response which was too high but as shown the message showed the read request value
    How can we modify the custom message so it also shows the write request value?
    I guess we could add {ITEM.VALUE2} but that would result in an empty value for all those triggers which have only one item
  • catkins
    • Feb 2020
    • 19
    Thanks Cyber, that worked well. The final custom message definition was
    Host: {HOST.NAME}
    Current value(s): {EVENT.OPDATA}
    And recovery
    Recovered at {EVENT.RECOVERY.TIME} on {EVENT.RECOVERY.DATE}
    Started at {EVENT.TIME} on {EVENT.DATE}
    That generated, example
    Host: cc1.example.com
    Severity: Warning
    Problem started at 14:36:03 on 2021.08.31
    Problem name: Interface Gi1/0/12(edge1-pulse): High error rate (> 2 for 5m)
    Current value(s): errors in: 0, errors out: 0
    Original problem ID: 428315
    Reason for "Current value(s):" is because, as in the example above, the values shown by {EVENT.OPDATA} can be zero while the trigger fired on a non-zero time average. At first I had "Value(s):" but that was misleading because the values displayed were not what had fired the trigger
