What does an "Unreachable Poller" process actually do?
  • woodwyatt
    • Sep 2021
    Hey everyone, I've been reading about zabbix-server pollers and I quite get what those processes are for - collecting data from passive agents & SNMP assuming the host is available.
    If the host becomes unavailable, unreachable poller process is created to check - what? I assume it's a lighter process that ONLY checks if host becomes available again so that the original poller process could continue gathering data?
    But I haven't found any valid information that would confirm my thoughts.
    I haven't faced any issues, just want to make sure that I understand the fundamentals behind these processes, any links, info sources would also be appreciated! Thank you.
  • woodwyatt
    • Sep 2021
    Based on 2011 blogpost - https://blog.zabbix.com/monitoring-h...esses-are/457/ unreachable poller does exactly the same as a regular poller, it is only concerned about unreachable hosts. I guess it's still valid.
