Is it possible to detect a change of host interface with a trigger?
  • lokha
    • Jun 2020
    • 15
    I use zabbix to monitor my java applications.
    Java applications are added to zabbix as a JMX interface.
    I have java applications sometimes moving between my hosts. In this situation, my script updates the JMX interface data in zabbix.
    Question. Is it possible to create a trigger to detect the JMX interface change?
  • Semiadmin
    • Oct 2014
    • 1625
    Hi, lokha!
    Yes, it's possible.
    Just create a text item with the type "Zabbix internal", key zabbix[host,discovery,interfaces] and JSONPath preprocessing
    $.[?(@.['{#IF.TYPE}'] == "JMX")].['{#IF.CONN}'].first()
    After that, you may create a trigger with function change().
    • lokha
      • Jun 2020
      • 15
      Thanks for the answer
