zbx 5.0 how to disable the sending of 'escalation disabled' messages for some actions
  • riBoon
    • May 2017
    • 30
    we have actions defined to send phone calls (via script)
    In Zabbix 5.0 we didn't find a option to disable 'escalation disabled' messages for this actions. (before in zabbix 4.0 they weren't sent if no recovery operation was set)
    Do you know a way how to get this done?
    Maybe this is not a new topic and I was searching wrong.
  • riBoon
    • May 2017
    • 30
    Have to push this with another question related to this:
    There are message templates for several things as I saw but not for 'Escalation cancelled'. Thats really bad because the 'Escalation cancelled' message for our type 'mail' suffers a good subject.
    Will have a look into the database but would be nice to have options in the gui. Or maybe I don't see them.
    Edit: Ok, I looked into this again and the 'Escalation cancelled' could be passed by the message template for problem. Will test it.
    • riBoon
      • May 2017
      • 30
      Ok, doesn't find anything in the database.
      Nobody has a hint for that?
