Hi
I'm trying to set up a lld using snmp for some switches.
For starters, I followed the tutorial / documentation. Unfortunately I'm getting this error:
After googling, reading old bugreports (all of them closed), I'm at the end of my knowledge. As far as I understood, zabbix has problems interpreting the name "IF-MIB::ifDescr" to its corresponding numeric OID. Or the underlying net-snmp components. But why? I can snmpwalk the device in question using the symbolic names (IF-MIB::ifDescr) and the numeric OID (0.1.3.6.1.2.1.2.2.1.2.1) as the zabbix user, so the underlying net-snmp should know about the installed mib.
Please advise me whats wrong here.
Current config:
zabbix 2.4 on FreeBSD 10.1, compiled with snmp (ammong others)
net-snmp 5.7 installed.
config of the discovery rule:
not mentioned values are on default.
Thaks in advance for any help
errorsmith
item "edgecore:ifDescr" became not supported: OID "discovery[{#SNMPVALUE},IF-MIB::ifDescr]" contains unsupported parameters.
Current config:
type: snmpv2 agent
Key: ifDescr
snmp oid: discovery[{#SNMPVALUE},IF-MIB::ifDescr]
snmp community: public
errorsmith
