Zabbix agent install fail
  • nicolasfo
    • Jul 2015
    • 56
    I'm trying to install zabbix agent on WS 2019 and i get this error :
    Product: Zabbix Agent (64-bit) -- Error 1720. There is a problem with this Windows Installer package. A script required for this install to complete could not be run. Contact your support personnel or package vendor. Custom action caGetNonMsiStatus script error -2146828235, Microsoft VBScript runtime error: File not found Line 319, Column 2,
    Windows Installer installed the product. Product Name: Zabbix Agent (64-bit). Product Version: 5.4.8.2400. Product Language: 1033. Manufacturer: Zabbix SIA. Installation success or error status: 1603.
    This is the first time i got his error. I made some tricks found on Google but nothing works..
    Any idea ?
    Nicolas
  • LenR
    • Sep 2009
    • 1011
    This is probably some Windows policy blocking script execution, not really a problem with the script (It's windows, embrace the suck). Can you tell what script is failing or how much got installed? The windows agent install is basically copy the bits, update the config and create a service.
    • nicolasfo
      • Jul 2015
      • 56
      I just installed Windows, so I reinstalled it and the agent is now OK.
      Big problems need big decisions
      Nicolas
      • aschild
        • Sep 2014
        • 25
        This error can happen, when the "Zabbix Agent" service already exists.
        Probably from some older installation which was not completely removed/uninstalled.
        In that case just remove the service from the registry, reboot the server and then the install should pass ok.
        HTML Code:
        sc.exe delete "Zabbix Agent 2"
        or
        sc.exe delete "Zabbix Agent"
        See also:
        • gelowe
          • Jun 2008
          • 30
          This was VERY, Helpful, Why can't the Zabbix engineers add some check in the installer?
          • ocelikdemir
            • Sep 2025
            If you face of this error on windows machine, you should remove the following registry keys:
            Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\EventLog\Application\Zabbix Agent 2
            Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\Application\Zabbix Agent 2
