Prevent a global script to run when trigger is reseted
  • melpheos
    • Dec 2008
    • 64
    Hi everyone,
    i am trying to prevent a script to run when a trigger is back to it's normal status.
    I borrowed a script that make a sip call when a trigger is in disaster status.
    Unfortunately, despite setting or not a recovery message, when the trigger is resolved i get another call a few minutes later.
    There is no options to set a recovery message when using global script and we can't use "even acknowledge" condition because the trigger might resolve itself.
    Any ideas ?
  • evertonco
    • Aug 2014
    • 75
    The only thing to do is uncheck "Recovery message" checkbox. Works for me.
    Maybe your action is not configured correctly.
    • melpheos
      • Dec 2008
      • 64
      Will try again
      Edit: actualy my last test wall already without recovery message and i still got a call when the trigger resolved
      • evertonco
        • Aug 2014
        • 75
        Show your action config
        • melpheos
          • Dec 2008
          • 64
          There is really nothing special
          One action
          From 1 to 1
          Remote Command
          Host : Zabbix Server
          Global script : Call Test
          Conditions :
          Label Name Action
          (A) Trigger severity = "Disaster"
          (B) Trigger name like "00 Ping Check"
          (C) Host = "DSM-FAQ"
          • ingus.vilnis
            • Mar 2014
            • 908
            You have to add another condition to your action.
            (D)	Trigger value = "PROBLEM"
            Since you don't have it, Zabbix executes an action at both states.
            Best Regards,
            Ingus
            • melpheos
              • Dec 2008
              • 64
              Best Regards,
              Ingus
              I think you are quite right indeed.
