vmware no communication
  • dddave
    • Jan 2022
    Can not get vmware macro to work and nothing of value in the server.log even after turning them up.
    Last 15 minutes
    8657:20220107:234620.000 zbx_setproctitle() title:'vmware collector #2 [updated 0, removed 0 VMware services in 0.000011 sec, querying VMware services]'
    8657:20220107:234620.000 zbx_setproctitle() title:'vmware collector #2 [updated 0, removed 0 VMware services in 0.000045 sec, idle 5 sec]'
    8656:20220107:234620.000 zbx_setproctitle() title:'vmware collector #1 [updated 0, removed 0 VMware services in 0.000010 sec, querying VMware services]'
    8656:20220107:234620.000 zbx_setproctitle() title:'vmware collector #1 [updated 0, removed 0 VMware services in 0.000086 sec, idle 5 sec]'
    8658:20220107:234620.000 zbx_setproctitle() title:'vmware collector #3 [updated 0, removed 0 VMware services in 0.000007 sec, querying VMware services]'
    8658:20220107:234620.000 zbx_setproctitle() title:'vmware collector #3 [updated 0, removed 0 VMware services in 0.000108 sec, idle 5 sec]'
    8657:20220107:234625.001 zbx_setproctitle() title:'vmware collector #2 [updated 0, removed 0 VMware services in 0.000045 sec, querying VMware services]'
    8657:20220107:234625.001 zbx_setproctitle() title:'vmware collector #2 [updated 0, removed 0 VMware services in 0.000044 sec, idle 5 sec]'
    8656:20220107:234625.001 zbx_setproctitle() title:'vmware collector #1 [updated 0, removed 0 VMware services in 0.000086 sec, querying VMware services]'
    8656:20220107:234625.001 zbx_setproctitle() title:'vmware collector #1 [updated 0, removed 0 VMware services in 0.000027 sec, idle 5 sec]'
    8658:20220107:234625.001 zbx_setproctitle() title:'vmware collector #3 [updated 0, removed 0 VMware services in 0.000108 sec, querying VMware services]'
    8658:20220107:234625.001 zbx_setproctitle() title:'vmware collector #3 [updated 0, removed 0 VMware services in 0.000068 sec, idle 5 sec]'
    8657:20220107:234630.001 zbx_setproctitle() title:'vmware collector #2 [updated 0, removed 0 VMware services in 0.000044 sec, querying VMware services]'
    8657:20220107:234630.001 zbx_setproctitle() title:'vmware collector #2 [updated 0, removed 0 VMware services in 0.000060 sec, idle 5 sec]'
    8656:20220107:234630.001 zbx_setproctitle() title:'vmware collector #1 [updated 0, removed 0 VMware services in 0.000027 sec, querying VMware services]'
    8656:20220107:234630.001 zbx_setproctitle() title:'vmware collector #1 [updated 0, removed 0 VMware services in 0.000081 sec, idle 5 sec]'
    8658:20220107:234630.001 zbx_setproctitle() title:'vmware collector #3 [updated 0, removed 0 VMware services in 0.000068 sec, querying VMware services]'
    8658:20220107:234630.001 zbx_setproctitle() title:'vmware collector #3 [updated 0, removed 0 VMware services in 0.000126 sec, idle 5 sec]'
    8657:20220107:234635.002 zbx_setproctitle() title:'vmware collector #2 [updated 0, removed 0 VMware services in 0.000060 sec, querying VMware services]'
    Any help would be appreciated.
    Click image for larger version  Name:	2022-01-07_18-56-59.png Views:	3 Size:	91.2 KB ID:	437878
  • Cocorino
    • May 2022
    • 23
    hello,
    Did you create your user in Vmware?
    good day
    • jhboricua
      • Dec 2021
      • 114
      What is 10.10.13.5 in your vCenter1 Host definition? This should be the Zabbix server so 127.0.0.1 should suffice. Also, did you configure the VMware parameters in the zabbix_server.conf file or setup an override file for them? I believe they are commented out by default.
      • dddave
        • Jan 2022
        Very strange I posted this in Jan 2022 (look at log output) but the post indicates Aug 1, 2022. I moved on to a different product do to the lack of response. Appreciate the response.
        • Cocorino
          Cocorino commented
          The form of the date would not be 2022/January/07 23:46:30
      • DaLoZ
        • Aug 2022
        • 25
        Could you try with just 'zabbix1' as username?
        You could also try to set the zabbix agent with DNS instead of IP.
        Can you add your ESXI hosts?
