zabbix-proxy unable to start
  • cTurtle98
    • Feb 2022
    background info:
    ubuntu 20.04 LTS virtual machine
    running inside Hyper-V on windows 11 pro
    zabbix 5.4.1
    PostgresSQL
    Apache2
    I have a machine on the local network of a site I manage. I enabled hyper-v and installed ubuntu 20.04 using the quick setup wizard from Microsoft.
    I installed zabbix client and zabbix server first.
    I got client working pushing data up to my gcp zabbix instance (it has both 127.0.0.1 and my cloud instance set as servers it pushes to
    I have zabbix server working as well no problem
    now I am trying to get zabbix-proxy to work so I can collect statistics on other local devices up to my cloud instance
    root@LOLIANET-ADMIN-LINUX:/etc/zabbix# service zabbix-proxy start
    root@LOLIANET-ADMIN-LINUX:/etc/zabbix# service zabbix-proxy status
    ● zabbix-proxy.service - Zabbix Proxy
    Loaded: loaded (/lib/systemd/system/zabbix-proxy.service; enabled; vendor preset: enabled)
    Active: activating (auto-restart) (Result: exit-code) since Mon 2022-02-14 18:15:08 PST; 5s ago
    Process: 278629 ExecStart=/usr/sbin/zabbix_proxy -c $CONFFILE (code=exited, status=0/SUCCESS)
    Main PID: 278631 (code=exited, status=1/FAILURE)
    Feb 14 18:15:08 LOLIANET-ADMIN-LINUX systemd[1]: zabbix-proxy.service: Main process exited, code=exited, status=1/FAILU>Feb 14 18:15:08 LOLIANET-ADMIN-LINUX systemd[1]: zabbix-proxy.service: Failed with result 'exit-code'.
    root@LOLIANET-ADMIN-LINUX:/etc/zabbix# tail /var/log/syslog
    Feb 14 18:15:19 LOLIANET-ADMIN-LINUX systemd[1]: Started Zabbix Proxy.
    Feb 14 18:15:19 LOLIANET-ADMIN-LINUX systemd[1]: zabbix-proxy.service: Main process exited, code=exited, status=1/FAILURE
    Feb 14 18:15:19 LOLIANET-ADMIN-LINUX systemd[1]: zabbix-proxy.service: Failed with result 'exit-code'.
    Feb 14 18:15:29 LOLIANET-ADMIN-LINUX systemd[1]: zabbix-proxy.service: Scheduled restart job, restart counter is at 24718.
    Feb 14 18:15:29 LOLIANET-ADMIN-LINUX systemd[1]: Stopped Zabbix Proxy.
    Feb 14 18:15:29 LOLIANET-ADMIN-LINUX systemd[1]: Starting Zabbix Proxy...
    Feb 14 18:15:29 LOLIANET-ADMIN-LINUX systemd[1]: zabbix-proxy.service: Can't open PID file /run/zabbix/zabbix_proxy.pid (yet?) after start: Operation not permitted
    Feb 14 18:15:29 LOLIANET-ADMIN-LINUX systemd[1]: Started Zabbix Proxy.
    Feb 14 18:15:29 LOLIANET-ADMIN-LINUX systemd[1]: zabbix-proxy.service: Main process exited, code=exited, status=1/FAILURE
    Feb 14 18:15:29 LOLIANET-ADMIN-LINUX systemd[1]: zabbix-proxy.service: Failed with result 'exit-code'.
    so I go touch that files
    root@LOLIANET-ADMIN-LINUX:/etc/zabbix# touch /run/zabbix/zabbix_proxy.pid
    root@LOLIANET-ADMIN-LINUX:/etc/zabbix# chown zabbix:zabbix /run/zabbix/zabbix_proxy.pid
    but it still doesn't work
    root@LOLIANET-ADMIN-LINUX:/etc/zabbix# service zabbix-proxy restart
    Active: activating (auto-restart) (Result: exit-code) since Mon 2022-02-14 18:18:36 PST; 5s ago
    Process: 278833 ExecStart=/usr/sbin/zabbix_proxy -c $CONFFILE (code=exited, status=0/SUCCESS)
    Main PID: 278835 (code=exited, status=1/FAILURE)
    Feb 14 18:18:36 LOLIANET-ADMIN-LINUX systemd[1]: zabbix-proxy.service: Main process exited, code=exited, status=1/FAILURE
    Feb 14 18:18:36 LOLIANET-ADMIN-LINUX systemd[1]: zabbix-proxy.service: Failed with result 'exit-code'.
    Feb 14 18:18:36 LOLIANET-ADMIN-LINUX systemd[1]: Started Zabbix Proxy.
    Feb 14 18:18:46 LOLIANET-ADMIN-LINUX systemd[1]: zabbix-proxy.service: Scheduled restart job, restart counter is at 1.
    Feb 14 18:18:46 LOLIANET-ADMIN-LINUX systemd[1]: Stopped Zabbix Proxy.
    Feb 14 18:18:46 LOLIANET-ADMIN-LINUX systemd[1]: Starting Zabbix Proxy...
    Feb 14 18:18:46 LOLIANET-ADMIN-LINUX systemd[1]: zabbix-proxy.service: Can't open PID file /run/zabbix/zabbix_proxy.pid (yet?) after start: Operation not permitted
    Feb 14 18:18:46 LOLIANET-ADMIN-LINUX systemd[1]: Started Zabbix Proxy.
    Feb 14 18:18:46 LOLIANET-ADMIN-LINUX systemd[1]: zabbix-proxy.service: Main process exited, code=exited, status=1/FAILURE
    Feb 14 18:18:46 LOLIANET-ADMIN-LINUX systemd[1]: zabbix-proxy.service: Failed with result 'exit-code'.
    any ideas? I use linux a lot and I have never had to deal with a pid file issue before. not sure where to go with this
    Access permissions in /run ? Even if you create a file with correct permissions, reaching that file requires correct permissions for all the directories in path also.
    • cTurtle98
      • Feb 2022
      /run/zabbix the zabbix user has full access to
      the pid files for the zabbix agent and zabbix server are in there and working
        Reading some older posts.. can you check, if there are maybe different pid file locations in server config file and in service file? Under /etc/systemd/system/....
        • cTurtle98
          • Feb 2022
          root@LOLIANET-ADMIN-LINUX:~# grep -v '^\s*$\|^\s*\#' /etc/zabbix/zabbix_proxy.conf
          ProxyMode=0
          Server=zabbix.cturtle98.com
          Hostname=LOLIANET-ADMIN-LINUX-PROXY
          LogFile=/var/log/zabbix/zabbix_proxy.log
          LogFileSize=0
          PidFile=/run/zabbix/zabbix_proxy.pid
          SocketDir=/run/zabbix
          DBName=zabbix-proxy
          DBUser=zabbix
          DBPassword=******************
          SNMPTrapperFile=/var/log/snmptrap/snmptrap.log
          Timeout=4
          ExternalScripts=/usr/lib/zabbix/externalscripts
          FpingLocation=/usr/bin/fping
          Fping6Location=/usr/bin/fping6
          LogSlowQueries=3000
          StatsAllowedIP=127.0.0.1
          root@LOLIANET-ADMIN-LINUX:~# grep -v '^\s*$\|^\s*\#' /lib/systemd/system/zabbix-proxy.service
          [Unit]
          Description=Zabbix Proxy
          After=syslog.target
          After=network.target
          After=postgresql.service
          [Service]
          Environment="CONFFILE=/etc/zabbix/zabbix_proxy.conf"
          EnvironmentFile=-/etc/default/zabbix-proxy
          Type=forking
          Restart=on-failure
          PIDFile=/run/zabbix/zabbix_proxy.pid
          KillMode=control-group
          ExecStop=/bin/kill -SIGTERM $MAINPID
          RestartSec=10s
          TimeoutSec=infinity
          [Install]
          WantedBy=multi-user.target
          • Robert N.
            • Feb 2022
            • 28
            Hi, Im solving the same problem. What do you have in the log ? LogFile=/var/log/zabbix/zabbix_proxy.log
              Found that we have in our service files additional lines to set permissions during startup.
              ExecStartPre=-/usr/bin/chown -R zabbix:zabbix /run/zabbix
              But you have already those set...
              Some stupid selinux error somewhere?
              • Damien_Dye
                • Apr 2021
                • 10
                can you start the proxy from your zabbix user on the command line fine ? as I find I need to rewrite the systemd unit for my use cases.
