Hi all,
I'm rather new to Zabbix so I'm looking for some help.
In my system setup I only use active agents which send their data on regular intervals to the Zabbix server. For your information, my agents are running on Windows OS.
I would like to perform a check in order to verify the agents are still running. Is there a possibility to do that in the case of active agents? Can, for example, a trigger be defined on the server that is fired in case no new data is received from the active server within a certain time limit?
Any help would be appreciated.
Thanks.
Thanks.
